#TBT | The epic tale of an ice resurfacer turned autocrosser
This $2000 Challenge entry met the rulebook approval by combining a Zamboni ice resurfacer with parts from a Mazda Miata and a Ford Mustang.
CNC machining, once cutting-edge technology, can now be performed in your garage.
Who among us hasn’t attached something special to a sticker? Exactly: zero.
What's the best way to join two pieces of aluminum? It often depends on the situation.
When you’ve gone a bit custom, you might well benefit from a standalone ECU.
Here are 25 nuggets we've learned from a lifetime of playing with cars.
A straightforward question came up as we worked on our Corvette Z06 project car: What are the rates for leaf springs–both OEM and some popular replacements?
Here are a few simple things you can do to make your workspace less miserable to work in.
Think you need lots of money to test your car's aerodynamics? Here's how we tested our C5 Corvette project car for less than $100.
Perform professional-level machining at home? You can do this. First step: drawing some plans.
