Remember when MSD only offered ignition boxes? Yeah, those days are long past. MSD claims that its Atomic AirForce intake manifolds offer improved airflow. Other niceties include lightweight polymer construction and a two-piece design that facilitates porting. The manifold works with both stock and oversized throttle bodies. MSD
[msdperformance.com](https://www.holley.com/brands/msd/)
(915) 855-7123
Putting an LS where there wasn’t one originally? Holley offers swap components for many popular projects, including F-bodies, G-bodies and midsize GM cars. The parts include oil pans, exhausts, cross-members and engine mounting brackets. Also cool: They’re available for the Nissan 240SX, too. HOLLEY
[holley.com](https://www.holley.com)
(866) 464-6553
AEM offers Plug & Play harnesses that easily mate its Infinity Programmable ECU lineup with LS crate engines. As AEM notes, this harness plugs into the factory subharnesses and uses the OE sensors. AEM
[aemelectronics.com](https://www.aemelectronics.com)
(310) 484-2322
If you’d rather not start off with a salvage yard special, Chevrolet Performance crate engines are as close as your local Chevy dealer or favorite speed shop. This factory performance arm has raised the bar again, too, with the LSX454R: 776 horsepower at an impressive 7000 rpm. As the name suggests, Chevrolet Performance punched this naturally aspirated LS to 454 cubic inches. Have a smaller budget? Brand-new LS crate engines start at less than $6000. CHEVROLET PERFORMANCE
[chevrolet.com/performance](https://www.chevrolet.com/performance/overview)
(800) 950-2438
MSRP: $24,037
That LS engine needs a transmission, right? American Powertrain offers an aluminum bell housing that mates an LS engine with a Tremec TKO, GM Muncie, T-10 or Richmond transmission. AMERICAN POWERTRAIN
[americanpowertrain.com](https://americanpowertrain.com)
(931) 646-4836
MSRP: $296.57
Fidanza Performance has added another lightweight flywheel to its line, and this one covers the Chevrolet Performance LSX crate engines. The custom conversion piece weighs just 11.8 pounds. FIDANZA PERFORMANCE
[fidanza.com](https://fidanza.com)
(440) 259-5656
MSRP: 485.27
Canton Racing Products initially designed this oil pan for LS-powered 240SXs, but its shallow front sump allows it to work with many other applications. How many? Enough to make it a company-wide bestseller. The pan also has a diamond-shaped baffle featuring four trap doors plus a removal windage tray. CANTON RACING PRODUCTS
[cantonracingproducts.com](https://www.cantonracingproducts.com)
(203) 481-9460
MSRP: $396
Not only does Scoggin-Dickey offer a zillion parts for the LS engine builder, but along with Raceshop it offers a full line of custom LS engines based on the 5.3-, 6.0-, 6.3- and 7.0-liter blocks. If you’re looking for a 416-cubic-inch LS3 featuring 10cc dished pistons, for example, they offer it. SCOGGIN-DICKY
[sdparts.com](https://sdparts.com)
(800) 456-0211
MSRP: $5349.87 (for engine 341610CSCHMF)
Which fasteners does ARP offer for the LS engine? Enough to fill a dedicated eight-page catalog. AUTOMOTIVE RACING PRODUCTS
[arp-bolts.com](https://arp-bolts.com)
(800) 826-3045
Driven Racing Oil offers an oil specially blended for LS engines. Meet their LS30, a 5w-30 synthetic oil said to reduce valve train noise and high-temperature shear. DRIVEN RACING OIL
[drivenracingoil.com](https://www.drivenracingoil.com)
(866) 611-1820
MSRP: $11.99/quart
Meet something new: JE Pistons that feature an asymmetrical forged design. These FSR pistons put more meat on the major thrust side while delivering less friction on the minor thrust side. And yes, the lineup covers many different LS applications. JE PISTONS
[jepistons.com](https://www.jepistons.com)
(714) 898-9764
Ron Davis Racing Products says it can build a custom aluminum radiator for any LS swap, like this one for the 1967–’69 Camaro. RON DAVIS RACING PRODUCTS, INC.
[rondavisradiators.com](http://www.rondavisradiators.com)
(800) 842-5166
Crane has added dual-valve-spring kits to its catalog for LS engines. Choose from steel or titanium retainers. CRANE
[cranecams.com](https://cranecams.com)
(386) 310-4875
Moroso offers competition-bred oil pans for nearly any application, including a 7-quart, low-profile unit that works well with LS swaps. Baffles and trap doors keep the oil near the pickup, too. MOROSO
[moroso.com](https://www.moroso.com/?SID=ac424ac03e366920ed3a70a04200db0930c41b4d)
(203) 453-6571
MSRP: $455.14
DIYAutoTune recently released a plug-and-play harness that matches its MS3-Pro Engine Management System to GM LS engines. All of the wiring is wrapped in self-extinguishing TechFlex woven loom. The harness uses OEM-spec connectors, too. DIYAUTOTUNE
[diyautotune.com](https://www.diyautotune.com)
(678) 261-8789
MSRP: $1599
Let’s say that you want to put LS power in something old school, like a G-body, vintage pickup or early pony car. Schwartz Performance has a ground-up solution: a fully reengineered, performance-tuned, bolt-in chassis that can come complete with LS engine mounts. (And yes, even though the Camaro and Firebird feature unibody construction, Schwartz Performance offers a frame for these cars–something to properly tie everything together.) SCHWARTZ PERFORMANCE
[schwartzperformance.com](https://www.schwartzperformance.com)
(815) 206-2230
MSRP: approx. $10,000 and up
C&R Racing makes a slew of products designed to cool water and air, including these bolt-in, high-performance intercoolers for the LS9 engine. C&R RACING
[crracing.com](https://www.crracing.com)
(317) 293-4100
MSRP: $1500/pair
Something for traditionalists: Edelbrock now offers a positive-displacement supercharger for LS engines. These E-Force Enforcer blower kits can work with dual carburetors or throttle body fuel injection. EDELBROCK
[edelbrock.com](https://www.edelbrock.com)
(310) 781-2222
Slipping belt? Concept One’s Victory Series HD Pulley System aims to stop that issue with an eight-rib belt setup. These conversion kits come with everything needed, including the heavy-duty tensioner. CONCEPT ONE
[c1pulleys.com](https://www.c1pulleys.com)
(877) 337-0688
MSRP: $2845 and up
Cooked spark plug boots and wires? Koolmat offers protective socks for different LS applications. KOOLMAT
[koolmat.com](https://www.koolmat.com)
(704) 662-9099
Chevrolet Performance can mate old school with new school. How’s that? It offers a full line of aluminum, four-barrel carburetor intake manifolds for LS engines. CHEVROLET PERFORMANCE
(800) 950-2438
Does Superchips offer a tuner for LS-powered cars? Of course. In fact, it stocks an entire line of them. SUPERCHIPS
[superchips.com](https://superchips.com)
(888) 227-2447
New for Holley LS Fest: The Grassroots Motorsports Road Course Challenge
Holley LS Fest celebrates LS-powered cars. GRM loves a good day at the track. Holley loves LS-powered cars. Put the two together, and what do you get? The Grassroots Motorsports Road Course Challenge, a new event added to the Holley LS Fest schedule that will debut at NCM Motorsports Park in Bowling Green, Kentucky. This will all go down near Beech Bend Raceway Park, Holley LS Fest’s base of operations. Participants will be grouped by skill level, and the Ultimate Street Car Association will sanction the event. Basic Holley LS Fest entry rules apply: Any car powered by a General Motors LS or current-generation LT engine can compete. The Grassroots Motorsports Road Course Challenge takes place Friday and Saturday, September 9-10, while the rest of the Holley LS Fest runs throughout the entire weekend. Details are at [holley.com/lsfest](https://www.lsfest.com). We’ll see you there.
This article is from a past issue of the magazine. Like stories like this? You’ll see every article as soon as it's published, and get access to our full digital archive, by subscribing to Grassroots Motorsports. Subscribe now.
