Slippery Slope
No matter how speedy a car is in stock condition, the owner’s manual isn’t going to spec an oil for a three-hour enduro or a home-brewed turbo setup. That’s when it’s time to do a little research and testing.
by Per Schroeder From the Oct. 2009 issue
For most of the motoring public, picking the right oil is easy: Simply follow the manufacturer’s recommendation. No matter what the make and model, trusty engineers have already determined the right viscosity for that particular car. Whether it’s 5W30 or 10W-whatever, the information is in the all-important owner’s manual.
However, you’re not John Q. Public.
Those who race, run added boost, or have dramatically raised the redline of their engine may have to determine their own viscosity needs. No matter how speedy a car is in stock condition, the owner’s manual isn’t going to spec an oil for a three-hour enduro or a home-brewed turbo setup. That’s when it’s time to do a little research and testing.
Timing the Flow
Whether it’s the latest and greatest synthetic lube or a discount petroleum product engineered to meet a price point, all motor oil is tagged by its viscosity. Oil viscosity, also known as its weight, refers to how thick or thin it is; the lower the weight, the thinner the oil.
An engine needs the correct oil viscosity to run well: The stuff must be thin enough to flow through the engine during cold starts, yet thick enough to keep lubricating when the engine is hot. Since a straight-weight oil gets thinner when heated and thicker when cooled, these two basic engine needs can be at odds with the basic nature of the lubricant.
This is precisely why multi-viscosity oils were developed. These products have different viscosities at different temperatures; as an example, a 10W30 oil has the viscosity of a 10 weight at 0 degrees Fahrenheit and that of a 30 weight at 212 F.
The viscosity is measured in a laboratory. An oil sample is brought to the specified temperatures and then allowed to flow through a standard-sized hole; the viscosity rating is determined by the length of time it takes the oil to flow out of the hole. If it flows quickly, it gets a low rating; if it flows slowly, it gets a high rating.
Follow the Rules
In most cases, we recommend using the oil viscosity that was specified by the car or engine’s manufacturer. For example, if a new Mazda MX-5 requires 5W20 from the factory, run that weight. If there are worries about that oil not having enough film strength for that particular car and its use, pick a better oil—don’t change from the recommended viscosity.
Most companies have moved to lower-viscosity oils in recent years. That’s not because of tight internal engine clearances, but because of the federal government’s penalties on manufacturers who fail to achieve their average CAFE mileage standards. Moving from a 5W30 down to a 5W20 can help a fleet squeak out just a hair better mileage; it may not add up to a real difference to individual consumers, but that little improvement can save big bucks for the manufacturers in avoided fines. (Many OEs have also tightened up their engine clearances in addition to using lighter oils, but it’s been only a very slight change.)
The best-selling oil weight in North America is 5W30—as it should be, because it’s a great viscosity for flowing through the many pathways in a modern engine. That’s why this weight is recommended by so many automakers.
Many old-school engine tuners, however, insist on running thicker oils. “We sell far too much 20W50 these days,” says Red Line Oil’s Cameron Evans. “It’s slowing down as people get clued in, but generally it is far too heavy for almost every passenger car or even many race cars.”
Many late-model cars come from the factory with an oil cooler or are fitted with an aftermarket cooler. Track day sessions tend to be on the short side, further negating the need for the really heavy oils. A heavy oil can also leave an engine vulnerable when cold, Cameron continues. High viscosities can also trap a lot of heat in the oil, which can make a bad situation even worse.
Blazing Your Own Path
Despite the usual recommendation to follow the owner’s manual, that helpful book isn’t going to be very relevant when the factory setup has been thrown to the wind. Adding boost, significantly raising the redline, and running long track sessions can put more strain on the oil.
In these cases, your oil temperature gauge will quickly become your best friend: Oil temperature can be a great guide for choosing the right oil viscosity. In fact, you’re going to have trouble determining which viscosity to run without a gauge.
Unfortunately, there’s a tendency to immediately jump to a thicker oil without this data. This often happens with mildly modified cars. An owner will add some basic bolt-ons—intake, exhaust, ECU tuning and so on—and then go with thicker oil because he assumes the engine is at the limit of what the factory 5W30 oil can handle.
Thanks to that heavier oil, the engine’s oil temperatures may never rise above 200 degrees while the car is on track. As a result, the oil never becomes warm enough to do its job and slows down the engine. Cold oil also accumulates contaminants more quickly than warm oil, meaning shorter service intervals.
While the 212-degree mark is a great target, it’s not always realistic. So if that same owner refills his engine with the factory-recommended 5W30 oil and then sees more than 212 degrees—something like 230 or even 240 degrees—there’s still no reason to panic. That’s where a great synthetic oil can help, as it still has plenty of film strength at those temperatures.
If the oil temperatures go beyond 260 degrees on a regular basis, that’s a clue to start looking at a different viscosity. The best synthetics are generally effective up to 300 degrees—which is where engine seals can start to fail. Heavier oils tend to carry more temperature as well. For example, if an engine is running hot with a 20W50 oil, switching to a stable 10W40 may very well lower the temperatures to a better zone.
And it’s okay to mix oil weights to sneak up on the the right viscosity for a particular application. For example, mixing 5W20 and 5W30 might yield ideal oil temperatures; in other cases, running a sump full of 5W30 and 10W30 may be the right answer.
Short of constantly pulling apart an engine to check the wear, that all-important oil temperature gauge is going to help you zero in on the right viscosity. While an old TV ad once proclaimed that motor oil is motor oil, having the right lubricant in your sump can greatly improve both performance and engine life.
Do Dinosaurs Need Dino Juice?
Older engines, like those now found in vintage race cars, have traditionally used heavier-weight conventional oils. Engine builders often follow this course, calling for very heavy viscosities like 20W50 and banning synthetics altogether.
The older engines’ wider bearing clearances and the lower thermal stability of conventional oils backed up some of these old-timers’ recommendations. However, today’s synthetics provide a viable solution. A good synthetic 10W40 is stable enough at higher oil temperatures to meet the needs of an older engine while providing more power than a thick petroleum 20W50.
Some have observed that older engines leak when filled with synthetic oil. The latest synthetic offerings contain chemicals that promote oil seal swelling, but that’s not the only potential culprit. Synthetic oils tend to have a better contaminant cleaning package, and the removal of sludge buildup in old engines can lead to new oil leaks.
Despite these issues, top vintage race engine builders are switching to synthetics thanks to the improved horsepower, wear resistance and thermal stability they offer. Older race engines can also be built to take advantage of synthetic oil’s benefits while relegating problems to the past.
Like this story?
Share & Save: What's this?
If you're reading this, you've probably seen these odd links with funny names somewhere on the site and want to know what they're all about. Well, prepare to feel a bit more Net savvy. Those links are what the geeks call "social networks."
Social networking sites allow you to store and share links and pages across the Internet. It's like taking your bookmarks list and being able to see it from any computer.
Even better, social networks allow you to steer friends, relatives, colleagues and pretty much anyone else to the cool stuff you've found, so they have something better to do online than watching the skateboarding squirrel video on YouTube for the thirtieth time. You're making the world a better place.
The only catch is that while all the social networks are free, you do have to register. Each site has a slightly different focus, so take a look through the links and see which service suits you best.
Tags:
Get the magazine
This story originally appeared in the Oct. 2009 issue of Grassroots Motorsports. Each issue of Grassroots Motorsports is full of great stories like this one, so click here to subscribe now. If you're not sure, request a free issue of Grassroots Motorsports.
Reader comments:
No comments have been posted. Perhaps you'd like to be the first? You'll need to log in or register!
