sampsond
sampsond
3/31/10 7:13 p.m.
FOR SALE: 1999 Dodge Neon Highline 4-Door Sedan 2.0L SOHC with Automatic Transmission ODO: 99K
  • Great car with excellent paint, body and interior
  • One-owner car, no accidents
  • New CA DMV Tags until March 2011
  • Does not run, camshaft position sensor fault code (I have been told this is a known issue with the Neon motor) but prior to this problem engine ran great
Because of the engine problem, I will sell the car for $1,000 OBO, you will need a trailer to pick up
The interior is in great shape so you can sell it to fund the new engine. For the full $1K amount, I can add a complete set of never-used sticky 14" tires.
Mazda787b
Mazda787b New Reader
4/1/10 12:43 a.m.
Where are you located? Are you sure it is a cam, or crank sensor? Usually it is crank which causes a no-start.
Edit - Wait, CA. Whether it be either sensor, they are inexpensive to buy and easy to replace. Good deal for someone looking for a DD
sampsond
sampsond New Reader
4/1/10 9:27 p.m.
In reply to Mazda787b:
The OBD scantool says it is a 0340 code which according to the internet is: Camshaft Position Sensor Circuit Malfunction
MCarp22
MCarp22 Reader
4/2/10 2:32 a.m.
You can unplug the cam sensor and the car will start and run, i'm going to vote for broken timing belt.
sampsond
sampsond New Reader
4/3/10 10:19 a.m.
SOLD and off to its new owner to try and figure out.
NmVskoJWYgMAUg8xFdAzbrgEo4D3LrPha3fcKQDCaLeUIUf8vzrrmaBe3ndhvPQJ
