Login to post Forums » $2011 Classifieds » 1.8 diff, RX7 clutch LSD, RX7 housing, MMR bushings
  • Pseudosport
    Aug. 11, 2009 12:27 a.m. Pseudosport New Reader
    While cleaning out the garage I noticed I have enough parts to put together another diff. For sale is an open 1.8L differential. I believe it came out of a 1999 and has 4.11 gears with 60k on it. Some light surface rust on one bearing cap and a few ring gear teeth. Nothing major should wipe off with some WD-40.
    0802091949
    It comes with a 1987 RX7 aluminum housing and clutch type LSD. LSD could use a rebuild or a shim. It has about 90k on it and when I place 2 stub shafts in I can turn them the opposite direction by hand (Note, this is just the diff. It still needs to be installed in the open 1.8L carrier). Housing has had the bushings removed and the new MMR ones are still in the box.
    0802091947 IMG_8221IMG_8223
    Found some RX7 stub shafts I'll throw in too. Please note they do not have the c-clips. I used them for my diff swap.
    $450
    Parts are located in Hingham, MA
  • Nov. 5, 2009 1:11 p.m. TheJWu New Reader
    pm'd
  • mw
    Nov. 6, 2009 9:32 a.m. mw Reader
    If you want to sell just the housing, let me know.
  • Nov. 8, 2009 11:23 p.m. TheJWu New Reader
    Let me know if you still have the RX7 clutch LSD and stub shafts.
  • Pseudosport
    Nov. 9, 2009 4:22 p.m. Pseudosport New Reader
    Sorry for the delay, I’m in the middle of moving. I was hoping to sell everything together but since there is a fair amount of interest I might separate the parts. I have replied to everyone’s PM’s so far.
