brokendub
brokendub
12/26/12 1:11 a.m.
Need to move on to greener pastures, this car has been a blast, but I need to part it out and buy myself a new place to live. Engine currently runs in the car, but the car is a heap, so im just parting it out. Engine comes out of a 98 Audi A4, but would be a great candidate for a swap into someones 80s or early 90s VW Also listed the head in here , because its attached to the motor and i'd love to sell it as a single unit! Also has a very nice big port cast intake manifold that can be included at extra cost!
email: mwc5078@psu.edu
Bottom End AEB code Block, bored 83mm with JE pistons (.080" over) ABA code crank for total displacement of 2008cc ARP Main Studs Scat Rods w/ ARP 2000 hardware Shaved oil pump shaft w/ lightweight gear Professionally balanced rotating assembly New timing belt kit! 200 miles $2012
Head Gasket matched AEB casting Supertech Inconel Exhaust Valves Supertech Stainless Steel Intake Valves Supertech High rate springs and retainers Stock Cams w/ lightweight Cam gear 500 miles $1200
p9drCOiMPMgMSyDsuJU6vVF2ghNgiTPVXxD8jRhT1MXcn3HzNAWkj5Kr1BHkIS4l
