Ron_Sutton
Ron_Sutton New Reader
4/13/18 10:56 a.m.
2018 Speedway Engineering Floater Rear End Promotion
Buy any Speedway Engineering Floater Rear End
& Speedway Engineering Will Buy You a Ticket to the
2018 Ron Sutton Workshop of Your Choice
Previous Speedway promos worked so well, we agreed to offer this for 2018 Ron Sutton Workshops also.
Speedway Engineering is a proud partner for 2018 Ron Sutton Workshop Tour. They are one of eighteen sponsors of the Ron Sutton 7 Secrets of Total Race Car Performance Workshop series that helped to bring the ticket price down from $1500 to only $349. If you’re in the market for the best 9” Ford based floater rear end in racing … and act now … the ticket won’t even cost you that. :)
Ron Sutton Race Technology is a long time Speedway Engineering Dealer and can help you get the details & dimensions for your rear end order spot on. Don’t worry about figuring out the width, pinion offset & brackets on your own.  Contact Dave Hanson & work out your ultimate rear end together.   844-722-3832  Ext 1
Complete Speedway Engineering 9" Ford Mod-Lite Floater Assembly  -  Only $1359
•    Brand New SVO Ford 9” Housing (10 gauge)
•    Vent, Fill & Drain Plug Fittings
•    3” O.D. x .188” Wall 1020 DOM Axle Tubes – Max Surface Welded
•    Premium Alloy Steel Axles, Double Heat Treated & Polished
•    4140 Heat Treated, CNC Machined Hubs Snouts TIG Welded
•    Forged 4140 Steel, Heat Treated Hubs with Bearings & Seals
•    8620 Steel Heat Treated Drive Plates - 2.50” Centric Snout Fits Most Wheels
•    Total weight around 76#
•    Lug pattern options: 5x5”, 5x4.75” & 5x4.5”
•    Stud Options:  1/2” or 5/8” – Short or Long
More Options & Info on Mod-Lite Floaters HERE & Grand National Floaters HERE
Ron Sutton Race Technology Options:
•    7 Brake Package Options from Wilwood & StopTech
•    Shipped Bare or with Suspension Brackets Welded On
•    Inner seals, aluminum hubs, HD Drive Plates, lightweight axles, cambered hubs, etc.
•    Custom Built 3rd Members with Soft Spring Lockers or Tru-Trac Differentials (See them HERE)
Notes:
•    50% Deposit on Rear End Required to be Eligible for Workshop Ticket
•    PIF Required Before Building Commences on Custom Rear Ends
•    Workshop Ticket is NOT-Transferable, nor resellable to another Person
•    Tickets Available for all 2018 Workshops:
  • Jasper, IN - April 22nd
  • Columbus, OH - July 5th
  • Ft. Worth, Texas - Sept 27th
  • Charlotte, NC - Oct 18th
  • Las Vegas, NV - Oct 31st
For more information on Speedway Engineering Floater Rear Ends – Contact Ron Sutton Race Technology:
Phone:  (844) 722-3832  Ext 1
Address: 11345 Trade Center Drive, Suite 450, Rancho Cordova, CA  95742
Website: www.RonSuttonRaceTechnology.com
Catalog:  www.RonSuttonRaceTechnology.com/catalog
Not buying a Floater Rear End but want info on the Workshops?  Go HERE
5Wh69F8HqQfwuBcdiSb1sFmfvwXHj61PTQykNmOsuZlVassFtgeAZicoKyidGQLU
