RockAuto
RockAuto New Reader
2/5/18 2:04 p.m.
  RockAuto now carries AJUSA parts! AJUSA is a leading international manufacturer of OE-quality automotive gaskets/sets, cylinder head bolt sets and hydraulic lifters. Like RockAuto, AJUSA is a family-owned company. They are now part of CRP Automotive which includes Continental, Pentosin and other respected European automotive brands.
Manufactured in Spain, AJUSA parts are available at RockAuto.com for a wide range of European and Asian brand vehicles. AJUSA parts meet or exceed OE specifications, plus they include additional features, such as the examples below, that make the parts easier to install and help ensure repairs are successful.
Head Gaskets & Gasket Sets:
  • MLS gaskets are coated in Viton to ensure the best possible seal by compensating for irregularities in engine block or cylinder head
  • Fiber-Max gaskets are covered in silicone for the best possible seal for cast iron engine blocks and cylinder heads (and often incorporate one-piece fire rings)
  • Each gasket includes a torque sequence and spec sheet
Head Bolt Sets:
  • Bolts are shrink-wrapped and come with assembly lubricant, ready for installation
Hydraulic Lifters:
  • Packaged in plastic trays that keep each part isolated, protected, and oiled (when required) until they are ready to be installed
Valve Cover Gaskets:
  • Gasket sets include spark plug grommets and other seals required for a complete repair
Whether you are looking for an Oil Cooler Gasket for a 2014 Mercedes-Benz G550, Rocker Arms for a 2008 Mini Cooper, Valve Cover Gaskets for a 2000 Lexus GS400, or Valve Lifters for a 1988 BMW 750IL, RockAuto has what you need from AJUSA. Look under multiple categories including Brake & Wheel Hub, Cooling System, Electrical, Engine, Exhaust & Emission, Fuel & Air and Ignition in the RockAuto.com catalog to see the AJUSA parts available for your specific car or truck.
YoxWhNxDhNLbiAyVyuf7NFMig7hwiEIMjAUbBFOVwBCre21S31BWMtBqPNOeUejW
