So, rallycross. Saturday was cancelled due to weather, but Sunday weather was perfect. out to Summit Point we went again, with almost 70 cars (and 17 in my class).
This event I went out with the car in full stage rally trim, much of which was not helpful for rallycross.
- Federal gravel tires on 15s: I usually run soft-sidewall grass tires on the rear to keep it in check at slower speeds. I don't much like stiff gravels back there since they don't have as good lateral traction on-throttle at low-speed turns and often result in washouts. This happened several times at this event. But, wanted to test them before STPR even though my usual tire setup would have certainly been faster and more controllable.
- Hawk HP+ pads: I put these on for STPR, but should have waited until after the rallycross. They take most of a run to get heated up enough to have any bite, which cost me a lot of time.
- Gp4 rear shock: They felt great at high-speed sections. The stiffer valving exacerbated the e36 rear springs and gravels on the rear to make it hard to lock the back down in power-on slow corners. Ideally for rallycross I'll go back to IX springs rear w/Maxsports.
- All the gear: carried the spare, jack, tools, fire extinguishers, etc. Also took a codriver for a couple runs (which were actually my fastest runs, as usual...). Even threw a second tire in for the afternoon to get more weight in the back. Plus a full tank of gas.
So, with that in mind, i kind of expected to be slower but who knows, right?
First run I actually put down the fastest run in the class - mostly because I go out aggressive and don't pick up much speed over the day, where most of the other top guys start more cautiously and pick up time (especially Nick, who watches the course on video between runs to learn the course better) #seriousbusiness lol.
Second run was also very fast until near the end, where the speed section ends in a 90* right-hand turn. Unfortunately, I went in a bit too hot and the brakes didnt' bite since I hadn't touched them for almost the entire run (see above). Overshot by a few feet into the "moon dust" and hit 3 cones. And in this class, 3 cones means game over, generally. The top guys don't hit any. 1 or 2 are recoverable with fast runs.
Third run, was being super-aggressive and made some mistakes and took out the finish cones (+4).
Fourth run, did some hooning for the photographers, with wide lines into the soft dirt to throw up clouds sideways, lol. +3 more.
At lunch, had 11 cones and was in 17th place (yup, last).
Meanwhile, car was dripping coolant. i initially thought it was the new coolant elbow I put in last week, but turns out it was the coolant level sensor leaking, as the threads for it were stripped and it coudln't be tightened. Good to find this out now. Wasn't a huge deal, still managed to not use too much coolant.
Fixed this morning with an expandable plug stopper (used for freeze plugs)
In the PM, took some passengers for joyrides and messed around a bit. 7th run Corey jumped in after he had just driven my car on a run, so i tried to run cleaner (and as noted, I like the weight of a 2nd person in this car). Shockingly, fastest time in the class on that run. And on my final run another fast time (but +1).
Managed to get back to 8th place without even trying - because who really cares lol.
Anyhow, Nick won, Stephen 2nd, Eisele 3rd. So, pretty much the usual top group (minus me). Seson points I'm 3rd overall now, but 2nd with our drop events included. We'll see how the rest of the season pans out, but now its time to focus on STPR.
Oh, and on the way home, on the Summit Point access road (a narrow-ish country road), a guy in a dually decided to hug the center line so i moved over to avoid him and dropped the trailer onto a pothole on the shoulder. Could hear the flat tire, but had to drag it almost 2 miles to find a safe pull-off spot.
doh
luckily, I had a spare, an impact, and a floor jack so not a tough change
