I get bored in the winter and as I don't have a garage full of airplane this year ....
Saw a Hobie 16 on CList for $80. I called, yep, it's really $80. They're remodeling their lake house and need room, and oh yeah, a squirrel ate the main sail. No worries, I'm making a motorboat anyway!
Took it all apart to get the tramp off and see what's what; also easier to handle a few big pieces. Plan is to run cross braces left to right and cover with 3/4" plywood and carpet. I can make up an engine mount, but factoring in the rudder control with the engine movement will have to be done once the engine is mounted. Coupla chairs up front and a cooler; I believe a 3.5 - 5hp will scoot is along smartly.
Dan
I vote for twin engines, one on each hull.
A pair of 5's would move it along very nicely.
759NRNG
SuperDork
8/13/18 8:03 a.m.
Are you running a bimini top or perhaps the more appropriate patio furniture wind up/down umbrella thingy?
In reply to 759NRNG :
I vote for a hang glider - it’ll provide a canopy, plus the lift will keep less of the hull in the water for increased speed.
759NRNG
SuperDork
8/13/18 8:35 a.m.
Will there be twin Flamigo figureheads ?
In reply to Pete Gossett :
That's ingenious. Is that a common mod?
I'm also picturing in my mind a cartoon version of the whole thing taking off in a big gust of wind...
I love everything aboat this.
759NRNG
SuperDork
8/13/18 9:24 a.m.
914 do you have your Admiral Pierbumper hat yet?
I had been planning to add an outrigger or extra hull for my canoe so I could run the 2.5 mercury I bought last year. A single hobie hull looks like it would work.
The project ground to a stop when I bought a miata and started autocrossing it, but I'm going to be picking up momentum again.
I’ve only been on the water twice, so I have no idea. Considering it popped into my brain I’m guessing there’s probably very valid reasons it’s not common.
Well, there is the matter of how much weight the hulls might be designed to carry. It might run pretty low in the water.
Dan: Have you googled this? You can't be the only person to come up with this idea.
Those of you that are worried this might not float, remember power solves all problems, so with enough power it will work just fine. Just keep adding more power until it works.....
I vote electric inboards. Plenty of room for mtors and batteries in the hulls. A couple of solar panels to extend battery life.
In the world of this kind of rowing...
...the coaches boat often looks like these...
Sample video: https://www.youtube.com/watch?v=w0OSveiJgJU
Here is also someone's detailed account of powering a Hobie
https://www.instructables.com/id/Convert-a-Hobie-Cat-From-Sail-to-Power-Cheap-Ponto/
Im drawn to this one...
Did that include the trailer for $80?
You've just invented the pontoon boat, the minivan of watercraft. Nobody really wants one but you can't deny their utility.
I like power catamarans as a concept, but they do have their quirks. Almost all of them lean towards the outside in a turn.
I picture a rowing coach just blasting Billy Squire’s “The Stroke” at full volume throughout their entire training session.
I dismissed them for years as floating patios for old people, but now I admit that they do look like a lot of fun.
759NRNG
SuperDork
8/13/18 7:35 p.m.
The following statement is only making this way more complicated than it should be....at this early stage in the 'build', if one were able to articulate the hulls(leaning.... AWS {all water steer}) relative to the desired direction....would that alleviate the pitch to the outside?
I got talked into rebuilding a pontoon boat, which I knew was a bad idea. Various issues, mainly getting legal title, but its been an awesome and versatile little boat. I even managed to waterski behind it with a 30hp suzuki, and it can do overnight adventure trips with a tent pitched on the deck. Plus a bunch of days just hanging out on the water drinking and grilling.
https://www.youtube.com/watch?v=R1WJAOn4pak
http://mattgent.com/riverrovers-i-oklawaha-silver-st-johns/
https://forums.bateau2.com/viewtopic.php?f=10&t=24678&hilit=pontoon
I've seen a few versions of the Hobie-toon. Keep it light! And/or do the tri-hobie-toon. Or make a center toon, use the "pontoon water glide" approach.
My little 16x8 toon can support a lot of weight (8 adults?), but the sponsons are way bigger than a Hobie.
Yeah, $80 for everything you see. Cut up the mast and got $18 at the scrapper. I thought about no rudders and two electric trolling motors, but what if you find yourself off shore and the battery dies?
Trish is the Flamingo Fan. One on the deck is 3ft tall cement guy, ones on the lawn are 1920's vintage cast aluminium.
