In reply to Greg Smith (Forum Supporter) :
I settled, at least for now, on malfunction indicator.
I have a LOT of wires at this point.....
32 AN in - 20 AN in +12 CAN AN in, 2 available
22 LS (12 for injectors, 10 other), 0 available
5 Temp In (but 2 I'm just using as 5V pullup for my external throttle driver father than put resistors in the wire harness), 1 available
6 coil (there are 6 after a board rewire to activate 2 of them left from older board rev, but FW only supports 10 total currently....begging for them to fix that)
6 digital in, 2 available ( 2 are unconnected but slated for brake and clutch pedal...needed if I want to try launch control)
1 VR in pair, 3 available
1HS, 2 available
So I have 0 LS, 1 HS and the DBW outputs left. The DBW I messed with tonight and couldn't quite get them doing what I want but I have a couple more ideas to try....hoping to get 2 usable outputs there. If I believe the 2 additional coils in FW are never coming I could take the 4 unused coil outs bur they are very low power HS on/off outputs so not very useful.
Tonight I connected the water temp gauge to the ECU and almost the low oil pressure light....but I ran out of heat shrink tubing to cover the splice (I had to cut the wire back as the OEM insulation was swelled and no longer fits in the ECU connector). I added some code to make the "slow down" light basically a check engine light that currently comes on with low oil pres, low fuel pre, high water temp....I'll add misfire and such later.
1 of the unused HS outs is for exhaust valves. I have 4 mufflers, 2 quiet (ish) and 2 loud. There are valves on the loud muffler and I have a solenoid valve that will open /close them. The quieter muffler should be good for 250-300hp which will handle all normal driving, then above that the gates of H_ll will open. Right now they are safety wired open, but I need to hook them up properly.
