So a quick update about DC region rallycross #7. I came into this event guaranteed at least a tie for the season points championship (with an 8th event remaining) - so basically I just had to finish in the top-8 or so to get a point. With that in mind, and the fact that I'm doing a "track-autocross" next weekend, I decided to re-install the sway bars for the tarmac. That said, I've never had the sways on with this current spring setup so wanted to see if they performed well at all on the dirt.
Swaybar install is as easy as ever, so I jumped in the car to test it out and.....the clutch pedal goes to the floor. Strange since I had just moved the car there an hour earlier. Under the car, a puddle of brake fluid. Dammit. It was pretty easy to trace the fluid to a blown seal on the clutch slave cylinder (which wasn't even new when I installed it 5 years ago, IIRC). With a day before the event, I had to get something pretty quick. I decided I might as well do the master and the soft line while I was in there. In retrospect I should have just done the slave and left the rest alone, because the master turned out to be a major hassle. Difficult to get to, difficult to get to the bolts, difficult to get to the feed hose, and with a cage in the car and fixed seats, it takes some contortion to get in there.
So after an hour on my back, head and shoulders scraping on the floor nonskid...it was in. While I was at it I installed a new braided clutch line from Condor Speed Shop that Carlos overnighted to me (thanks!). So it all works fine now, back to normal. Yay.
On to rallycross. NIce weather, nice courses, nice conditions. The whole MOD RWD crew was there, with 11 or 12 cars registered, including Josh Sennett, trying to finish an event in the M50-swapped e30, and Nick finally with the e36 M3 ready to go. Of course Eric/Neil were there in their e30, battling for 2nd in season points, Eric H/Stephen in their e30, a BR-Z, a couple Volvos, etc. SA front-runner Mike Golden sheared a couple wheels studs before the event and asked for a co-drive, to which I said yes.
Anyhow, the long and the short of it is that the car is terrible on grass/dirt with the sways. Damn near uncontrollable, understeering heavily on lower-speed turns then snapping to oversteer with no warning. And it would NOT rotate on command except at high entry speeds with heavy trail-braking. So I was entering corners faster than usual just to try to get the car to snap, which it did inconsistently. And it was awful in slaloms - could not get it to "dance" the way I always can.
So, the long and the short of it is that even pushing as hard as I could, the best I could manage was 3rd, almost 10 seconds behind Eric Eisele and 4-5 behind his codriver Neil. Too bad since the courses would have been excellent for my normal setup.
Interestingly, Mike Golden (who did poorly when he drove my car last year) finished just tenths of a second behind me in the end. I guess as a Subaru driver he's used to the understeer, lol....
All that said, I locked up the points championship for the second straight year, so that's nice.
This coming weekend I'm heading up to Summit Point Raceway for the "refrigerator bowl" autocross, which is set up on two of the tracks (Jefferson and Shenandoah circuits), has very few cones, and no course working. I thought about taking the WRX but nah...taking the rally car with the old Star Specs on it. Should be interesting, and probably very slow haha...
Oh a few other things...
rusty e36s don't like rallycross (though he ran the rest of the day with no rear shock)
Also, don't use steelies for rallycross. This is the second time a car has had this happen in the last few events....
