Woody
Woody MegaDork
11/20/12 6:22 p.m.
My '87 Porsche 911 coupe came with an inflatable/collapsible spare tire. In addition to combining a heavy wheel with a heavy tire, you also need to carry an air compressor in the car at all times. As far as I know, my spare has never been inflated in the past 25 years and, if it were to be, I'm not sure that it would hold air or fully collapse into its original shape when subsequently deflated. Because the spare wheel fits snugly into a recess in the 22 gallon fuel tank, there's not really any room for a full size tire.
During one of my daily Craigslist searches, I found a nearly perfect 14x5.5 inch Fuchs wheel that was originally fitted to a 912. In addition to its beautiful condition, it's really light. My original plan was to flip it for a quick profit, but then I started to think about using it in place of the heavy collapsible spare that came with my car.
I started by confirming that the wheel would clear the front brakes on the car.
Photobucket
I measured the collapsible spare and it was approximately 20 inches across, with a small gap between it and the fuel tank. I wouldn't have room for anything bigger. I thought back to the small 14 inch temporary spare tires in my old Miata track cars. I found that a Miata spare is 19.5 inches across, when inflated on its 4 inch wide rim. I quickly acquired one in exchange for a twelve pack of Smithwicks.
Photobucket
I had to go to three tire shops before I could get someone to mount the tire onto the Porsche wheel. The first two shop said that it couldn't be done. I had to work my way down to progressively less skilled technicians until I found one who didn't know any better. The third shop mounted it with a new valve stem for a total cost of $4.
Photobucket
The tire is really stretched, but he was able to seat the bead and it holds air without leaking.
Photobucket
Photobucket
I didn't want to use the original steel hold-down on the beautiful forged aluminum wheel, so I dug through my big pile of Fuchs center caps, picked out the crappy one, drilled a hole through the center and sent it for a trip through the sand blaster. I also picked up a slightly longer metric bolt, along with one composite and one neoprene washer. The result was a precision fitted hold-down for my new light weight spare.
Photobucket
The new spare fits perfectly into the recess in the fuel tank and I can easily check to see that it's holding pressure.
Photobucket
The old steel wheel and collapsible spare weigh 34 pounds and the compressor added another 4.5 pounds. The new spare wheel and tire weigh 16 pounds, for a net savings of 22.5 pounds.
chandlerGTi
chandlerGTi Dork
11/20/12 9:01 p.m.
Sweet, my brother is rolling around on 165/45/15 on 8" wheels which looks unsafe and silly at the same time. That should work great for a spare though, great idea!
mndsm
mndsm PowerDork
11/20/12 9:51 p.m.
LOL VW guys woulda done that E36 M3 for a daily. Well played sir.
dculberson
dculberson SuperDork
11/21/12 10:49 a.m.
WOW! Saved 22 pounds, that's actually quite impressive. Good job.
I laughed at the "work my way down to progressively less skilled technicians" part. I know of a couple shops that would probably mount it, and you're right, they just don't know any better.
octavious
octavious Reader
11/23/12 7:39 a.m.
Good job.
Now wanna find another one for me and set it up for a 12er of Smithwicks?
Nathan JansenvanDoorn
Nathan JansenvanDoorn Dork
11/23/12 9:26 a.m.
Nice. I wonder if that would clear 964 brakes... Of course, I suppose an AAA card would save another 15.9 lbs....
mblommel
mblommel Reader
11/23/12 9:55 a.m.
Now all you need is 3 more just like it an you can hang out with the hellaflush cool kids.
Seriously though, great job on weight reduction.
Giant Purple Snorklewacker
11/23/12 10:15 a.m.
Nathan JansenvanDoorn wrote: Nice. I wonder if that would clear 964 brakes... Of course, I suppose an AAA card would save another 15.9 lbs....
The wheel won;t fit a 964. I wish I could use sexy Fuchs from the older cars but there is no way I know of to get them in there except to buy look-alikes made for the later cars.
I still have the factory 964 inflatable spare in there but save a wee bit of weight with 2 cans of Green Slime to inflate it with since my car didn't come with a compressor. I carry a plug kit too so if I run over a nail or something I can fix it up on the side of the road. I have actually used it successfully too - in the paddock at Pocono a friend ran over something and we plugged it right there so he could drive home. Relying on AAA is going to ruin your whole day. They will have to tow you somewhere.
Woody, that works and it looks great too. Very cool.
jXY7LrU1D5EuXp77AEZJaez5mQzr6ivJzi9tXl88rumY4p8jAlLqbegwAYUVKPbY
