1 ... 20 21 22 23 24 ... 52
Professor_Brap
Professor_Brap GRM+ Memberand Dork
1/21/20 1:17 p.m.
In reply to JeremyJ :
It's sorted. It was a ignition lock actuator pin. Easy fix.
Professor_Brap
1/21/20 4:09 p.m.
Bent-Valve
Bent-Valve HalfDork
1/21/20 7:54 p.m.
Only 600k on the truck? wink A little bitty John Deere? laugh
I kinda figured it was something like that.
Do they still have those ignition switch parts new somewhere? I have rebuild many locks and ignition switches from multiple sort of working units, but a complete replacement NOS always works better.
Professor_Brap
1/22/20 5:48 a.m.
In reply to Bent-Valve :
I got a new dormant actuator pin ignition cylinder in it 2 years ago. The truck is good to go again.
Professor_Brap
1/22/20 5:17 p.m.
Red Omni is tore down, it was definitely a bad belt. Got it together and it fires up and purrs like a kitten.
Professor_Brap
1/23/20 6:49 p.m.
Retimed, test fired, one small fire and a dash of sad.
First test fire it back fired out of intake and got a good flame, 2nd fire sounded like a knock due to alt bracket flopping. I'll upload sound of alt bracket bouncing video in a bit.
Wicked93gs
Wicked93gs New Reader
1/23/20 8:33 p.m.
I do miss the dodge 4 cylinders and how easy it is to change timing belts...the only engine easier is the Ford 2.3 Lima engine(I timed that one at a little over 30mins for a timing belt)
Professor_Brap
1/24/20 5:41 a.m.
In reply to Wicked93gs :
This was 2 hours from pulling the tools out to setting on ground.
Professor_Brap
1/24/20 5:46 a.m.
Professor_Brap
1/25/20 5:31 p.m.
Finished up red Omni....
Here is a good one.
Drove it around the block, parked it, went to restart it cranks strong back fired out intake.
Need to dig a little deeper tomorrow and get it fixed.
Professor_Brap
1/26/20 11:17 a.m.
Way to cold today to want to mess with it.
Changed the oil in tabbie and greased her.
Painted the new oil pan for aRTic
Professor_Brap
1/27/20 7:15 a.m.
Hello,
I'm Wes and I'm a hoarder.
Dusterbd13-michael
Dusterbd13-michael MegaDork
1/27/20 7:17 a.m.
Hi wes!
Professor_Brap
1/27/20 7:30 a.m.
This is my newest neon. Magenta sedan sohc auto.
Unsure what it's fate will be, but any way it will be cool. Not a car I will be touching this year, ya know... Due to having way to many projects and other stuff to focus on.
Professor_Brap
1/28/20 4:45 p.m.
Did the oil pan on artic tonight.
Found this gem, glad I cough to early
Also 99% sure cam or crank seal is leaking
Dusterbd13-michael
1/28/20 4:53 p.m.
Naw, it was fine!!!
Professor_Brap
1/28/20 4:58 p.m.
Chains cut now. Just went on a test drive. No Ballance shafts make it so lively.
Professor_Brap
1/29/20 6:18 p.m.
Making the time this weekend for this....
Professor_Brap
1/31/20 4:54 p.m.
Scrach this. Life got in the way.
Professor_Brap
2/1/20 9:50 a.m.
Made a junkyard run this morning for focus parts. Damn DDs breaking when I wanna do fun stuff. Also got a dizzy for the 88 Omni to try to diag some weird missing issues
Professor_Brap
2/1/20 3:17 p.m.
Why beater car is best car and the donor car for sensors and a dizzy
Professor_Brap
2/2/20 8:48 a.m.
Ol pos runs decent. Got to fix a high idle issue. PO claimed new plugs wires cap and rotor ... That was a lie
Professor_Brap
2/3/20 6:48 a.m.
3 omnis.
One carbed
One tbi
One mpfi turbo...
All have unique sounds
https://youtu.be/xo-y2QK28fA
Professor_Brap
2/4/20 5:53 a.m.
The Dodge Omni
Professor_Brap
2/5/20 11:03 a.m.
This gave me a good laugh.
Bt7vi20evlftFejDce0I4P6BW8ZOR1amOQoRMWhF4rV69MAu3dOhLZ7QiLMT5ynV
