I'm already thinking about replacing the highway tires on my 2013 F150 with ATs. These HTs are useless in even the smallets mud patch. Not going to lift it, but I might eventually level the front up a little and that probably won't even happen until I need to replace the shocks somewhere down the road.
I've been looking at tire sizes to gain any advantage I can for running around on dirt roads and mild forest trails.
Stock tire size is 265/70-18.
Biggest I can fit WITHOUT the level is 275/70-18
In the tire model I'm looking, the stock tire is 32.6" diameter and the 275 is 33.2" , so it gains 0.60" total height and about the same in width. So I would gain apprx 1/4" under the axles. They cost about $20 more per tire depending on the vendor, plus I would also have to buy a $230 Hypertech programmer just to correct the tire size in the computer. Not because the speedo is off (who cares) but because the NAV builds a cumulative error over time if the tire size is off. And the 275/70 was never a stock size on any model so the dealership can't reset it (which would only cost $100.)
So it would cost me over $300 to gain 1/4".
Pretty sure I'm going to going back with the stock size, lol. Once I level it I can go up to 34" tires...so I can at least get 3/4" for my $300....
No real point to this post, just grousing.
You're probably better off spending that extra money on a good set of skid plates. A 1/4" won't do a lot to keep you from banging parts on the ground, but skid plates will do a lot to prevent damage when you do smack something.
That's what I figured. It's an FX4 package, so it has some skids already. The funny thing is one main skid under the trans is heavy plastic, not steel. But I can make it steel for about the same cost as the tire upsize. I don't plan on rock crawling the thing, but there is always the chance for things to get out of hand!
Surely it would self correct using the GPS from time to time?!
In reply to dculberson :
From what I can read, yes....but apparently the time span makes it highly annoying / approaching unusable (if the peeps on the F150 forums are to be believed.)
I mean...GPS..shouldn't that use...youknow...SATELLITES??!!
_
Reader
1/8/19 1:43 p.m.
I know of men that would pay triple that to gain a 1/4”... of course, these men aren’t buying tires.
After continued digging I found a thread with an answer...yes, tire size was throwing off the NAV on the first '13 F150s but some guys found a fix....unhook the battery (neg cable, specifically) for 2 hours. It worked for everyone that tried it regardless of tire size changes or wether or not they reprogrammed the size in the computer. Maybe I'll go bigger and take a chance...
