Login to post Forums » Grassroots Motorsports » 1998 Mercury Villager Tow Miata and Trailer
  • granth
    April 30, 2010 5:33 p.m. granth New Reader
    So how do you feel about a 1998 Mercury Villager towing a miata on a trailer or tow dolly. The van has a tow rating of 3500 lbs so that would be fine LBS wise. But how about how well it will tow anyone done this?
    TIA....
  • mw
    April 30, 2010 7:49 p.m. mw HalfDork
    As long as you trailer or tow dolly isn't heavy, it should be fine. Just don't drive it like you're driving a miata and leave a bit of space.
  • Carson
    April 30, 2010 7:51 p.m. Carson Dork
    aeronca65T tows his Midget race car on a dual axle trailer with a (newer) Ford Windstar. I know that the Villager is not a Windstar but it's the closest real-world example I could use. According to him, a lot of vintage racers are using minivans (I'm sure someone is using a Quest/Villager) as tow vehicles. Miata's fall into a similar weight category as a lot of vintage racers.
    You might want to message him for first hand experience.
  • April 30, 2010 10:35 p.m. petegossett SuperDork
    I had to pull a Neon home on a tow strap this week behind our '00 Villager & it was no prob, so I'm sure you'd be ok with a dolly.
  • pres589
    April 30, 2010 10:45 p.m. pres589 Reader
    I would be concerned with heat buildup in the trans as much as anything. I have no easy solutions to suggest for this but it's something to keep in mind.
  • iceracer
    May 1, 2010 9:28 a.m. iceracer Dork
    An auxilliary cooler will help the transmission live.
  • shadetree30
    May 1, 2010 10:03 a.m. shadetree30 New Reader
    That and regular fluid exchanges. Is it Mercon V?
    I flat towed a GTI with a '98 Windstar, including a trip to New Hampster International. As long as you take the precautions mentioned you should have no problem.
  • granth
    May 2, 2010 2:21 a.m. granth New Reader
    Thanks, also do you think it would make it over the grapevine here in LA? From sea level to about 4500 feet then back to sea level.
    http://en.wikipedia.org/wiki/Ridge_Route
  • granth
    Jan. 8, 2011 9:37 p.m. granth New Reader
    Update on villager GRM tow vehicle
    It really works well for the miata on the dolly, I replaced the tires, shocks, flush the trans fluid and added a full size spare (it only had a "dounut" tire) I added some lead tongue weight on the dolly and got some "D" rated trailer tires.
    Here is the best part with all the seats out of the van I can carry all of my tires and tools to the track inside and still put spare tires on the roof rack if needed. On the last trip to Button Willow I got 19mpg with this setup.
    http://www.brakefade.com/files/pics/Auto/Mercury_Villager_1998/Towing/Mercury_Vill...
    What more could you ask for, total investment:
    Van $1,200 class III hitch $160 tires: $300 tow D tires: $180 rear shocks: $50 trans flush: $40 steel wheel: $30 Lead: FREE
