Login to post Forums » Grassroots Motorsports » 2000 CR-V misfire
  • bigbrainonbrad
    July 9, 2010 1:37 p.m. bigbrainonbrad New Reader
    Helping the gf's brother in law fix the family hauler, check engine light was on code was a misfire. Has new plugs, wires, cap and rotor, and is getting spark. Exhaust smells heavily of gasoline. When listening with a screwdriver you can hear the fuel injector ticking. My educated guess is a stuck or clogged injector (#1 in this case). Sound like I am on the right track or way out in right field? What other honda/acuras used the same injectors?
  • petemc53555
    July 9, 2010 4:00 p.m. petemc53555 New Reader
    check compression, w/o exhaust valve adjustment they will burn'em. Good luck
