Check this out:
http://www.designnews.com/article/511949-Additive_Manufacturing_Technology_Expands...
'The photo shows an exhaust manifold laser-sintered out of EOS NickelAlloy IN625.'
OK, a manifold is not quite the same as a set of headers, but it's just a metter of time until it's possible. More immediately, turbo manifolds should be no problem. Use CAD to design exactly what you need for a given motor, in a given vehicle, for a given turbo and location. Hit the 'print' button, wait for the 3D printer to finish the job. Oh, need the turbo moved 1/2" to the right? Edit the CAD file, hit 'print' .....
How long until we can make custom cylinder heads the same way? (DOHC 16 valve Spitfire anyone?) Or truly custom bell housings? EFI intake manifolds? Suspension uprights? Engine blocks?
Carter
