Some of my days are slow enough that I can get away with thinking bad ideas a bit farther through than I really should.
This particular bad idea involves the following: Yamaha R1 engine (with close ratio sequential 6 speed) Suzuki Samurai transfer case Miata rear and Sportage front differentials Long travel double wishbone suspension at all corners with miata rear uprights and sportage fronts and to top it off, a 95+ Geo metro shell with tubular chassis underneath, driving position moved nearly to center.
Like so...
Ideally built initially on a challenge budget with a cheapo superbike 4cylinder, 1500lbs max. Geared for a top speed around 90. Yes, it would have a locked center diff when in 4wd, but could also be driven in 2wd. Will I ever build it? Not likely. Would it be awesome if it worked? I think so.
So what do you think, is it even feasible? Would the R1 powerplant have the gusto to spin all four in the dirt? Would it's transmission puke its guts out?
