Jerry
Jerry UberDork
9/5/18 9:13 p.m.
Driving home in the WRX, 94F-ish degrees so I've got the AC going pretty well.  10-15 minutes into the drive, I can barely feel the fan but hear it running.  I even crank it up to #4 and hear it but barely feel anything.  Then I notice fog coming from the vents (not smoke, it's fog).  I'm on the highway so I say berkeley it and turn off the AC, turn off the fan, roll the window.  I'm almost home anyway.
I get to the bottom of the offramp maybe 5 minutes later, decide to try again.  Everything is working fine...  Is something just freezing up?  ('02 WRX for reference)
Run_Away
Run_Away GRM+ Memberand Dork
9/5/18 9:15 p.m.
Evaporator is freezing over.
Strizzo
Strizzo PowerDork
9/5/18 10:15 p.m.
froze it up.  usually it means low freon, but I've had it freeze up before just because it was super humid out and I had been driving with the windows down for a bit.
Tyler H
Tyler H GRM+ Memberand UltraDork
9/6/18 6:03 a.m.
I've seen them freeze up due to inadequate airflow -- mouse nests or clogged cabin filters.
Jerry
Jerry UberDork
9/6/18 7:00 a.m.
Hmm.  I'll check the filter, after some dusty rallycrosses what are the odds?  Otherwise summer is almost over for now anyway, maybe deal with it next spring.  (Google-fu mentioned water leaking into the system somewhere?)
mazdeuce - Seth
mazdeuce - Seth Mod Squad
9/6/18 7:29 a.m.
We had that happen, twice, in the One Lap Civic. A can of R134 fixed it both times. Now would be a good time to check your pressures and if they're low, add a can with dye in it.
Vigo
Vigo UltimaDork
9/6/18 9:20 a.m.
Pretty much all systems have low-pressure cutoff switches or evaporator temp switches which are supposed to cut off the compressor to prevent this from happening, so there's a good chance something in the system has failed. Maybe more than one, as usually the operating pressures in the system won't get the evaporator cold enough to freeze. You probably have low refrigerant AND a failed failsafe of some kind.
Jerry
Jerry UberDork
9/6/18 3:49 p.m.
Winning!
Antihero
Antihero GRM+ Memberand HalfDork
9/6/18 3:53 p.m.
I have the same thing going on moreor less, although with mine a bump will turn it back on. Its on my winter list of things to do
mtn
mtn MegaDork
9/6/18 4:05 p.m.
You say you can hear it, but barely feel it. What happens when you shut off the AC and just run the fan? Do you notice it slowly losing strength, or is it just like a switch is flipped?
This almost sounds like there is a relay issue too, otherwise wouldn't the fan continue to run?
Jerry
Jerry UberDork
9/6/18 6:47 p.m.
In reply to mtn :
Have to try again, I'm not sure.  Finally cooling off for a few days, it might be awhile before I have to use it again.
mazdeuce - Seth
9/6/18 7:14 p.m.
For what it's worth, when we had the core freezing up we'd manually cycle the compressor every 90 seconds or so, keeping the fan on, and we could get fairly consistent cool air that way. Fun way to drive across the country. Way better than no AC at all.
Aspen
Aspen Reader
9/7/18 11:53 a.m.
My subaru does this too, because there is no low pressure switch in the system.   It was left out when the engine swap was done.  I just run the a/c for 5 minutes or so, switch off for a minute or two, repeat.  Works well enough.
s4yESySmWj5Z1YnddAcL3OaOuVGEGxQXVr8efulqrJNIfzv7jXJVUG40qhzneuWz
