slantvaliant wrote:
DWNSHFT wrote:
Finally, add a bunch of downforce and you add a ton of stress on the suspension and chassis.
FWIW (and since someone already mentioned Chaparral), notice that in the Chaparral 2E, Hall put the downforce from the big moveable rear wing directly to the rear uprights. That bypassed the chassis and most of the suspension. When that was banned, Chaparral looked more at ground effects. That’s where the sucker car came in.
I’m not sure how moveable wings, rear uprights, and suckers apply to a Pontiac Lemans, but , then, this IS GRM.
I appreciate you posting this. I was unfamiliar with the 2E.
Can someone give me a run down of this car, particularly it's aero features? I am seeing a lot of interesting things, but I'd like a little clarification.
Pics of the 2E
So, I see that the movable wing transfers directly to the rear uprights. It is operated by a foot pedal. Was this outlawed because of it's effectiveness, or because of the potential for driver error?
It looks like the front wheels have vents at the rear side of the fender to eliminate the negative pressure space behind the front tires.
There is almost no frontal area or chin spoiler, but it appears that the car pulls air from under the front and ducts it through the hood to the negative pressure space a the cowl. What's the undercarriage design like?
I am also noticing the radiators are moved to the rear. Is the air pulled down from the vents above, or ducted through the boxed chassis? Does it dump into the rear wheel wells and out through the rear deck? What is the net contribution of this element? What do the intakes in front of the rear wheel do?
I see very little similar to modern aero- no chin, no front splitter, no rear splitter, no side skirts, nothing deflecting the air directly at the rear of the car.
Can anyone describe the basic flows and concepts?
Thanks!
