Login to post Forums » Grassroots Motorsports » Alfa timing--??
  • Feb. 3, 2012 5:08 p.m. triumph5 SuperDork
    I'll be replacing the clutch on an '88 Alfa Spyder Quadrifoglio, and the owner is telling me the transmission has to be "timed" with the engine, when installing the new clutch, or the engine will not start. This sounds absurd to me, but then, I've never worked on an Alfa Spyder. Can anyone enlighten me? Thanks in advance.
  • Feb. 3, 2012 6:15 p.m. triumph5 SuperDork
    Anyone?
  • mad_machine
    Feb. 3, 2012 6:16 p.m. mad_machine SuperDork
    I know the GTV and Milano needed the torquetube balanced with the clutch.. but unless you are pulling the flywheel.. I do not see why you need to time the engine to the transmission
  • alfadriver
    Feb. 3, 2012 9:45 p.m. alfadriver SuperDork
    Check and see if you can find a engine speed pick up off the back. I have heard that the Bosch picks that up off the back of the engine but have no first hand knowledge.
  • alfadriver
    Feb. 3, 2012 9:46 p.m. alfadriver SuperDork
    Oh and alfabb.com may help too
  • mad_machine
    Feb. 3, 2012 9:47 p.m. mad_machine SuperDork
    wouldn;t that pick up off of the flywheel though?
  • alfadriver
    Feb. 3, 2012 10:21 p.m. alfadriver SuperDork
    Yes, but I don't know where the sensor is. I kinda doubt that there is real timing needed, though. Should be fixed and controlled by the ecu
  • drmike
    Feb. 3, 2012 11:36 p.m. drmike Reader
    I think he's mixed up the flywheel and the gearbox. There is definitely a steel "nipple" on the flywheel that rotates past a sensor (two sensors?) that plugs into the bellhousing. But, there is nothing special about the gearbox.
  • mad_machine
    Feb. 4, 2012 7:18 a.m. mad_machine SuperDork
    I didn't see how there could be. Just shifting would change the "timing" between gearbox and engine. Everytime you pressed the clutch, it would change
  • Streetwiseguy
    Feb. 4, 2012 7:33 a.m. Streetwiseguy SuperDork
    Later model red block Volvos use a crank sensor with the pickup on the flywheel. The bolt pattern on the crank is symmetric, so the flywheel can be bolted on in any location, causing dramatically incorrect ignition timing.
    Perhaps this is the situation he was trying to explain to you.
  • alfadriver
    Feb. 4, 2012 12:41 p.m. alfadriver SuperDork
    Seems as if the owner is mixing things up a little. Timing is taken off of the flywheel, but it's not adjustable. On the other hand, if you forget the input, the car won't run.
    Basically, put it together like you took it apart, and it'll be fine.
