5/22/20 8:47 a.m.
Story by Lane Borg
A straightforward question came up as we worked on our Corvette Z06 project car: What are the rates for leaf springs–both OEM and some popular replacements?
So we asked Lane Borg, a mechanical engineer, Formula SAE instructor, Goodyear test driver and owner of Borg Motorsports, manufacturer of bespoke high-performance chassis bits for Corvettes. As it turns out, this question was waaaaay too difficult for our primitive lizard brains to tackle. His response required more than 1200 words.
Producing relevant data for Corvette transverse leaf springs can be immensely complicated because there are lots of variables and dynamic reactions affecting the action. There’s more going on than a simple energy absorption and release.
Coupefan
Coupefan Reader
5/22/20 2:48 p.m.
I'm still freaked out over their design choice. I know they work, like the old vacuum tubes we see in some audio gear, but still, I'm freaked out by the use.
5/22/20 3:57 p.m.
In reply to Coupefan :
You know, maybe the vacuum tube analogy is a good one. (Says the guy sitting beside two tube amps.)
5/23/20 10:44 p.m.
I wonder if you could go old school and stack leafs to change the rates?
Cooter
Cooter UberDork
5/24/20 9:04 a.m.
In reply to Appleseed :
You could conceivably make multileaf packs, but then you end up with all of the downsides of a multileaf pack.
Pete. (l33t FS) MegaDork
5/24/20 9:36 a.m.
There are a lot of dynamic as well as packaging benefits to their use.
wspohn
wspohn Dork
5/24/20 11:30 a.m.
Hey - as I type this I am sitting in front of a tube power amp fed by a tube preamp. Nothing wrong with tubes (or valves as the British call them), and certain military gear has long used tubes because they are much less problematic in an EMP (electromagnetic pulse) from a nuclear explosion.  The fact that Russian planes used tubes extensively for that purpose accounts for the continued popularity of Russian made (usually Sovtec) tubes in hi-fi.
(I also have a couple of systems that use 120 lb Class A mono solid state amps, so I go both ways). The irony is that my tube power amp puts out 70 W while my Class A amps put out 45 W (but they do it right down to 1 ohm).
BTW - very interesting spring article - thanks.
hnbm7PEhLnlq03ByN9awfVgo7NR5Ksb0gdZqIO0eCTzhtn3c4gqPHmRwXOYjyTo7
