Travis_K wrote:
There are pretty much 3 choices on the timing belt tensioners, none of them are terribly good, but its just part of owning one. The stock tensioner used oil pressure to take some of the load off the belt at higher rpm, so it lasts longer, but they require rebuilding everytime you change the belt (or even more ferquently).
Yeah, I saw that one over on alfabb. Some folks like that one, but say that you really have to be tender with the engine until oil comes up to temp. I got the impression that there is no tension on the belt until then.
Travis_K wrote:
Or you can block the oil feed to the stock tensioner and it will still work fine.
Really? Has it got a "big assed spring" in it or something? I'm not doubting you, dude...I'm just trying to get it running again without berkeleying up something.
Travis_K wrote:
Or you can get a mechanical one, which has a spring that can break if you install it wrong or it wasnt made right, and you replace them every belt change.
Sure sounds like I've got to change the tensioner every time I change the belt anyway..I guess I just want the one that extends the engine's life the most.
Travis_K wrote:
On the alfabb, check the 164 section for timing belt stuff, its mostly the same engine, and there is alot more info there.
Thanks. One of my old SCCA Worker buddies had a 164 for awhile...I thought it was a great car, but didn't really pay much attention to it, since I didn't think I'd ever own one.
Thanks for the tip!
Travis_K wrote:
I think the gtv6 has the pulleys that the center part is seperate, if so changing the cam seals doesnt require taking the belt off, but its easier to do it all at once anyway.
Something I've read over at alfabb..it looks like the cams can be taken off to do the valve gap without taking the cam gears off. Could I also take the cam gears off to do the seals without removing the cams?
Travis_K wrote:
I dont think it will hurt if you split the caliper halves, I did when i did mine and they dont leak.
I think that if they've been dry for this long, the calipers won't have corrosion on the internal parts. The fluid ports should blow clean with a little WD40 and a lot of compressed air.
Travis_K wrote:
Changing the cv boots is a bit complicated, mainly just figuring out how to press the shaft out of the joint, but if you need help i can explain how i did it.
Dude, I'll be sure to ping you if & when it goes that far.
Thanks again, Travis.
