Well I bought a 1988 Ford F350 (Roll back) over the weekend with a 460 V8 four speed trans (stick) and have a question about oil pressure and coolant temperature. The factory instrument cluster dose not seem to work very well and I do not trust it.
Ambient air temp 102* (F) for all readings.
Cold oil pressure 60 PSI
Hot oil pressure 26 PSI
Hot oil pressure at 2K RPM (round about) 45 PSI
Water temperature measured at radiator neck 160* (F) after running for about one hour.
Now I am a Mopar guy myself but I have worked on a number of Fords over the years the number I have posted do not raise any flags for me, another person thinks the oil pressure is to low.
So before I go putting real money into this truck I want to make sure the engine will hold up. The truck made a 250+ mile trip on a recored breaking hot day.I would think if it made it through all of that the engine must not be in bad shape.
Thanks Paul B
