Since the BS meter has been running pretty deep on the Mustang thread, how about we talk about it over here?
Real ideas.
Anyone know the real rules? What cycle the milage is measured on, acceration requirement? Emissions, crash, etc?
Uber Grassroots idea.... Start with a CRX HF.
I know my '88 was capable of 60mpg under abnormal conditions, and normally 55mpg. So a 100% increase? Yikes.
Knowing trends (and what we are workin on), I would say smaller displacement turbo- if we can maintain ~1800-1900 lb weight, a 70hp target peak power would be decent enough. Plus 90-110 lb-ft would be good enough too. Which says we have a slow spinning enigne- the later HF motor had a 5200 rpm red line, with some key bits that were not intended to spin fast...
Since we want torque and not speed, lets find a 1.0l Twin, turbo it lightly, and try to run as lean as possible.
Drag reduction is pretty important, too- I would close up the front end some to keep the air going around the car, and put on a full body belly pan. Nice narrow tires etc etc.
Not sure how far that would get, but knowing the car, I bet 75mpg is pretty realistic.
A not so uber GRM idea.
If currnet crash rules are part of the competition, I would start with a Elise chassis. Why? Weight, mid engine, and crash certified.
Of course, weight is huge for economy- light = less power needed to acceleration. The Elise is the lightest current production car- so we have one that is pretty crash tested.
Alter body to change emphasis from downforce to drag. Great chassis for that, since it's already got a flat bottom. Narrow tires will help.
Powertain? Remember, performance isn't the idea- so one could probably do well with a 80hp, 100lb-ft engine. Not awe inspiring in any sense, but one must target needs for the program. That will give us a pretty small motor if we go light boosting. Diesel? Perhaps. Small gas DI? Perhaps- lots of good possibilities.
I really think that it's possible to do an Elise chassied car that will get close to 100mpg under the right condidtions.
Anyone with a spare lotus?
Eric
