So the wife was enjoying Senior Dos over the weekend, when the car suddenly would not go into gear after being parked. After a tow home, my guess is that it is low on clutch fluid. No idea where a leak could be, I don't see anything under the master or slave cylinder at all. So I decided to bleed the system. I was able to get some pressure back and the car will shift OK, but all of the friction occurs in the first 1 inch off the floor. Way to abrupt, still not right.
When I am bleeding it, I see no bubbles coming from the line at all. Seems like solid fluid, no foam, no pockets, no bubbles. So am I missing something?
