Login to post Forums » Grassroots Motorsports » B6T Help needed
  • dansxr2
    July 26, 2010 8:58 p.m. dansxr2 Reader
    So my Capri XR2 has been kinda fussy lately. On occation it just wont start. Cranks normally just wont start... I'm at a loss of what to do right now... I noticed that the problem was intermittent and started around 7-10 days ago and have diagnosed it as a no spark condition. Here's the rub... I initially thought the car was suffering from the infamous ignition module so to confirm it I swapped distributors with my step dads XR2.... to no avail.
    There is power at the ignitor (12.5v) and the problem is intermittent. I pulled the loom looking for a break as when you wiggled it around it would start no problem... After taking the harness loose, removing the loom, and tracing the wires I didn't see any pinched or proken wires. I did however find a green wire that has an exterior wire layer that is similar to coax one end meets up with a black and yellow wire and the other has nothing on it just taped up.
    Also I noticed that my CEL is recently inop. Tomorrow I'm gonna check if the bulb is blown or possible related to my cars issue. Any ideas?
  • Nitroracer
    July 26, 2010 9:19 p.m. Nitroracer Dork
    I had an intermittent no start problem with my probe that involved a faulty crankshaft position sensor. Check the wires and orientation of the cam & crank sensors.
  • Keith
    July 26, 2010 9:33 p.m. Keith SuperDork
    Not that I know the Capri - but a shielded wire (such as your coax wire) is usually a sensitive signal such as the O2 sensor or possibly the AFM. Since the car ran before, I'm guessing the former.
  • dansxr2
    July 27, 2010 10:35 p.m. dansxr2 Reader
    I'll take a pic of the section of the harness in question. as the distributor was replaced and the issue still exists. Anyone have an engine harness on the cheap?
  • dansxr2
    July 27, 2010 10:40 p.m. dansxr2 Reader
    its either the ECU, Ignitor, of the harness. I'm gonna work on it all day the next 3 days as i have them off work... so I hope it get it lined out. I'm gonna call the dealership and get the wiring diagram and make sure i have power at the correct places and filter through what it could be... Wish me luck!
  • dansxr2
    July 28, 2010 4:19 p.m. dansxr2 Reader
    FIXED: It was a corroded plug by the over flow bottle.
