So the day before yesterday my clutch cable snapped, It was less than 2 months old... The end on top of the pedal where the pellet holds the cable pulled off. I have it repaired as a temp fix by welding the end of the new cable to the old cable i cut off (the adjustment was siezed to the cable, IE NO ADJUSTMENT). So I've saved me up some $$$ and curious what I should money on. The car is currently my DD, but I have access to another car should the need arise to use it. I occationally will do autoX with it but would like to get more power out of it. What to do?
Megasquirt, Flywheel & Clutch (it will need a clutch sometime in the future), Electronic Boost Controller, MX-6 Intercooler (already have just need to install), Upgrade the Turbo with an MX-6 Compressor or Tbird TC), I'm really up in the air.
I have the car running very well. Installed new Timing and Drive Belts, Plugs, Wires, Cap, Rotor, T-Stat & Coolant Flush, Oil and Filter, 2.25" Exhaust, and an Open Filter.
Input appreciated...
