Well I finally tore into the 530i I towed back from TN on Saturday.
Things that need attention:
- Valve Cover Gaskets
- PCV
- Clean the intake
- Coolant Flush
- Water pump
- Belts
- Front suspension rebuild
- Struts and shocks
Here's what it ran like: Lil Smokey (Courtesy of Tyler H)
I pulled the spark plug covers and coils and there was nearly 1/2 quart of oil in there . . . per side
I also pulled the intake manifold and it was a ton of oil behind the intake under the PCV as well as inside. . . GASKETS FOR E'ERYONE!!
I'm going to order all of the gaskets and cooling system stuff today (I have a PCV on the shelf). Suspension stuff later once I decide what to replace it with (stock = no)
