Login to post Forums » Grassroots Motorsports » Boost Leak Testers
  • 93celicaGT2
    Aug. 8, 2010 5:33 p.m. 93celicaGT2 SuperDork
    ARE AWESOME.
    Went from 19 inches of vaccuum at idle to 22 inches of vaccuum at idle, with faster spool up, and MOAR POWAH.
    That is all.
  • unevolved
    Aug. 8, 2010 7:15 p.m. unevolved HalfDork
    Boost leak testers? I've always used two PVC pipe caps, with a valve stem drilled in one of them. Pressurize to 50 psi, come back in an hour and measure again.
  • 93celicaGT2
    Aug. 9, 2010 9:51 a.m. 93celicaGT2 SuperDork
    That's kindof what i used... except used a air compressor fitting.
    I found two MASSIVE boost leaks that i had, actually almost directly off the compressor side. Cranked them back down, shuffled a little bit, and we were golden. Idle doesn't bounce when you come to a stop anymore, spool up is way faster, and seem to have picked up some power on the butt dyno. (probably from the spool up.)
    Next stop? 20psi.
  • ansonivan
    Aug. 9, 2010 12:30 p.m. ansonivan HalfDork
    I have access to a pressurized smoke machine at work, mother of schnitzel what a time saver. Intake tract integrity is now one of the first things I test with any new car I acquire.
  • unevolved
    Aug. 9, 2010 1:04 p.m. unevolved HalfDork
    That's pretty cool, I didn't know they made a special tool for that.
  • Keith
    Aug. 9, 2010 1:06 p.m. Keith SuperDork
    Smoke machines can save your bacon. It's not a tool you use every day, but when you need one, you need one.
  • smog7
    Aug. 9, 2010 7:19 p.m. smog7 Dork
    have any pictures of your tester?
  • 93celicaGT2
    Aug. 10, 2010 5:27 a.m. 93celicaGT2 SuperDork
    I can get pics, give me a couple days. Buddy has it right now working on his MR2.
  • ansonivan
    Aug. 12, 2010 3:13 p.m. ansonivan HalfDork
    Picture of the smoke machine I'm using... crappy picture but you just see the smoke whisping up from a leaking oil separator. This thing uses 12v from the car to heat mineral oil and shop air reduced to 5 psi to pressurize the smoke. It has a little flow meter which gives you an idea of the air leak size or ideally, lack of air leak.
  • Wonkothesane
    Aug. 12, 2010 3:55 p.m. Wonkothesane Reader
    Where did they get that one? Any idea how much do they go for?
  • Strizzo
    Aug. 12, 2010 3:56 p.m. Strizzo SuperDork
    In reply to 93celicaGT2:
    ...isn't that what i told you was going on when you suddenly started hitting boost cut out of nowhere? well, glad it worked out, i'm not bitter
  • 93celicaGT2
    Aug. 12, 2010 4:06 p.m. 93celicaGT2 SuperDork
    Well... i'm still hitting boost cut in the same place. But that's simply because of how boost cut works on this car.
    I could disconnect the charge pipes entirely from the car, and it would still hit "boost cut" at the same point.
  • ansonivan
    Aug. 12, 2010 4:13 p.m. ansonivan HalfDork
    Came from some indy mobile tool truck guy, believe it was $600.
