Login to post Forums » Grassroots Motorsports » Brake Pads Keep Rotors, or Eat Them
  • Mac951
    Sept. 19, 2008 10:54 p.m. Mac951 None
    Time for new Brake Pads on my Auto-X machine. Problems are: 1 I drive it on the street; 2 its a Porsche (Read $$$)
    I've scoured the internet for various brake pads that are decent for autosing, however I seem to get stuck on the "I've used these and they are GREAT" mentality, only to find that suggestor has had them installed for 5 miles.
    I see HAWK everywhere, and know that they are an SCCA sponsor, however, I also hear that they tend to eat rotors. Again, I am looking at the most bang for the buck. I do drive the car on the street, so all race pads are out. Well, for autoxing, alll race pads wouldn't heat up, so there. Currently I have PBR on my Porsche, and my DC5 type-S has fresh stock Acura pads. Before I start a huge thread, here is the information I require.
    Car: Give all the general info here: IE Make, Model, Year, Estimated weight, Use, Wheel change from stock Tires, Tire size, Brake modifications, and finally Brake pads.
    History Please mention what you use your car for, how often you maintain your car, how your find the parts to hold up in any driving condition you encounter.
    Example:
    Car 1986 Porsche 944 turbo. Slight power mods only to replace broken factory parts. Wheels changed to 17x7.5 front, 17x9 rear with Bridgestone RA-1Rs. Wheels exceptionally heavy due to cheap replicas. Tires are AWESOME. Car has been lightened 2896lbs overall, front biased. Brakes all stock ATE Blue in the lines PBR pads. Rotors are old, probably should be turned, and or replaced. Medium fade, but good pedal response allows me to adjust as needed. Autoxing allows me the cool down time between runs. Have found that I can selectively lock the rear tires under braking mostly due to suspension set-up, however, to better feel the limit I will upgrade to SS braided lines.
    Get the picture? Good, please let me know what you use, and how you like the brakes. I love the PBRs, however, I don't have any idea if there is anything better out there.
  • Jack
    Sept. 20, 2008 9:18 a.m. Jack SuperDork
    Great question, as our stock Volvo brakes (2005 XC90) have taken the rotors down too. I'm changing both soon, at 45k miles and going with Okebono pads - which are not neccessarily high performane, but are low dusting. I had used these brakes on my 2002 Subie Legacy GT (3,600 pounds, stock everything 205x55-16 tires) and they were great on the street with agressive (at times) driving, no fade and no apparent rotor wear in 10k miles.
    Jack
  • iceracer
    Sept. 20, 2008 9:30 a.m. iceracer Reader
    The Hawk HPS pads work very well for auto cross and are easy on rotors. I now have HP+ and so far, I haven't noticed any excessive wear. I'll be running a track day in Oct. then we will see. a lot of people say the HP+ pads are noisy, Mine are just as quiet as the HPS were.
  • iceracer
    Sept. 20, 2008 9:40 a.m. iceracer Reader
    I didn't answer all your questions. My car is a 2000 Ford ZX2-SR. weight a little over 2400 lbs. Tires are 205x50-15 Hoosier R6's. I use stock type rotors.
    I have been using Hawk HPS pads with good results but I decided to go with the Plus for a more agressive brake. The car is a DD also. I changed the front rotors due to caution from rust around the hat.
