Login to post Forums » Grassroots Motorsports » Brake product idea
  • Streetwiseguy
    Aug. 21, 2010 8:18 p.m. Streetwiseguy HalfDork
    This is either a free idea for brake fluid manufacturers, or a request for info on who already makes it.
    I was prepping my IT car for next weekend, and part of the deal was changing brake hoses and bleeding/changing brake fluid. With a normal old dd, the fluid you are bleeding out is years old, used and dark colored, and its easy to tell when you have the fresh fluid coming out. With a race car, its not so easy to know when you are done, and i"m cheap enough I don't like the idea of draining more $25/liter Dot4 650 degree fluid than I have to.
    Here is the product- Dye for brake fluid- available in different colors so you can drain out blue and wait for pink. Better yet, make it temperature sensitive, so when it hits, say, 500 degrees it changes color. That way, you can bleed the fluid thats gotten hot and damaged at the calipers, but leave the fresher stuff thats in the master cylinder.
    Any chemistry majors out there? Or does it already exist?
  • porksboy
    Aug. 21, 2010 8:37 p.m. porksboy Dork
    Coloured fluids are already available. I belive ATE makes it. Put a different colour in the resivoir than previously and wait for the new colour.
  • unevolved
    Aug. 21, 2010 8:42 p.m. unevolved HalfDork
    Yep, ATE Superblue. Aside from being awesomely blue, it's pretty good stuff. Just alternate between ATE and and another comparable normal-colored brand (Motul RBF660, etc).
  • Keith
    Aug. 21, 2010 10:55 p.m. Keith SuperDork
    ATE Super Blue is also available in non-blue with a less awesome name - ATE Boring Amber or something. But that's exactly why, so you know you have a full flush.
    Interesting note - Super Blue is not street legal in Florida due to the color.
  • irish44j
    Aug. 21, 2010 10:58 p.m. irish44j HalfDork
    ATE Super Blue
    ATE Gold
    specs are identical. 536* dry.
  • Streetwiseguy
    Aug. 22, 2010 11:37 a.m. Streetwiseguy HalfDork
    I always have these good ideas that somebody already has done. That blue is what I want.
  • iceracer
    Aug. 22, 2010 12:01 p.m. iceracer Dork
    Regular bleeding and adding of new fluid kind of negates the need.
  • wbjones
    Aug. 22, 2010 6:49 p.m. wbjones Dork
    good thing they don't stop me and check my Integra when I'm there for the Rolex... I've been using Super Blue for several yrs...
    one thing to think about before using Super Blue is that it'll stain your entire system.. making it harder to spot the change to Amber than it really should be.. the stain doesn't ever seem to go away
  • jungle
    Aug. 31, 2010 12:28 p.m. jungle New Reader
    only thing about this product is i don't like the squishy pedal feel I get.
  • Aug. 31, 2010 12:39 p.m. Nashco SuperDork
    Are you talking about the brake fluid? If you think you have a squishy pedal because of Super Blue (compared to..???), you're doing it wrong.
    Bryce
  • Tom Heath
    Aug. 31, 2010 12:51 p.m. Tom Heath Webmaster
    Shhh! Are you trying to get me in trouble?
  • sobe_death
    Aug. 31, 2010 1:23 p.m. sobe_death Reader
    Bryce
    No, he's right. I swapped to the ATE blue in my S2000 and ever since then the brakes have felt mushier as time goes on. This has been challenged by a whole system flush, gravity bleed, pressure bleed, and vacuum bleed; nothing seems to fix it. Even my girlfriends S2000 which has probably never had a fluid flush in its 5 year life has a much firmer pedal feel.
  • turboswede
    Aug. 31, 2010 2:20 p.m. turboswede SuperDork
    your master cylinder or brake lines are on their way out or you have flex in the pedal system.
  • digdug18
    Aug. 31, 2010 2:56 p.m. digdug18 HalfDork
    So a previously non changed brake fluid could have been masking those kinds of problems?
  • RedS13Coupe
    Aug. 31, 2010 3:33 p.m. RedS13Coupe Reader
    Forget brake fluid.
    I want motor oil dye for checking fluid levels at the track. Fresh motor oil is too damn clear.
    I have been tempted to just add a few drops of coloring... what could it hurt? (The only problem is I have no idea what it could hurt...)
  • novaderrik
    Aug. 31, 2010 3:40 p.m. novaderrik Reader
    RedS13Coupe wrote:
    Forget brake fluid.
    Royal Purple oil is.. purple..
  • turboswede
    Aug. 31, 2010 5:13 p.m. turboswede SuperDork
    The act of bleeding the system can force the master cylinder past its normal area of operation, where crud can build up overtime, and damage the seals.
  • wbjones
    Aug. 31, 2010 7:20 p.m. wbjones Dork
    that's where mine is now.. .. new one on order.. but won't be here in time for this week at Mid-Ohio ... oh well guess I'll just have to continue pumping with my left foot as I approach the corner so I'll have brakes when I need them
