I have several questions about brakes.
April 20, 2009 4:49 p.m. 96DXCivic Reader
April 20, 2009 4:59 p.m. iceracer Reader
Remember, brakes stop the wheels, tires stop the car.
April 20, 2009 5:03 p.m. 96DXCivic Reader
I am aware of that fact. These brakes are for a FSAE car. And one of rules states that you must be able to lock all four wheels under braking. I have figured the equations to find the brake torque but how do I know if this is enough to lock the wheels.
April 20, 2009 5:06 p.m. fiat22turbo SuperDork
1) Without actually going out and trying it? You'd have to do a lot of math and model the car, the driver, the environment, the tires, etc.
If you want to how to tell when driving, try hitting the brakes hard, if the car brakes in a straight line and leaves four black marks, then you're in good shape. If it spins, then the rear is locking up first. If it slides relatively straight then it is probably only the fronts locking up.
2) Dunno
3) Assuming you aren't looking at carbon and/or ceramic braking systems, it should be the same as nearly any other car as the pads will have a working heat range and you have to balance the braking system components to work with this range. The amount of thermal mass you need to dissipate that heat between braking cycles is different given the mass of the vehicle.
April 20, 2009 5:16 p.m. AngryCorvair Dork
brake torque divided by rolling radius of tire equals retarding force at contact patch. if that is greater than the product of the corner weight times the peak grip of the tire, then that tire will lock up.
all equations from pedal to contact patch are in the june '08 GRM, "Think Globally, Stop Locally"
April 20, 2009 5:23 p.m. 96DXCivic Reader
2) Dunno
We are a basically rookie team so we have no car to play with. So I was put in charge of the brakes and I am having to work thru all the equations.
April 20, 2009 8:14 p.m. billy3esq Dork
I know I'm asking for it questioning a well known braking system article author and real life brake engineer, but does the corner weight used in your calculation above need to be a dynamic one that accounts for the weight transfer under braking? Or, is the effect of the weight transfer so slight for something like an FSAE car that it doesn't really affect the retarding force at each wheel? Or, is there some other reason I haven't thought of that the static corner weight can be used?
Full Disclosure: I have not reviewed my copy of "Think Globally" recently.
I'm not trying to be a smartass, I'm really curious. (That's the second time I've posted that disclaimer today.)
April 21, 2009 9:02 a.m. AngryCorvair Dork
Yep, it's a dynamic weight, so you'd use the peak mu of the tire as the decel in the weight transfer equation.
No, static isn't good enough. This is a race car, and if it ain't 100% right then it might as well be 0% right.
But seriously, in the real world, only the engineer on the car can say whether or not good enough really is good enough. Run the numbers with static and dynamic values, and see if the difference would force you to change component sizing or prop valve settings.
April 21, 2009 1:10 p.m. 96DXCivic Reader
Is the peak grip the same as the coefficient of friction between the road and the tire? (I don't have that issue but I am going to order from the store)
April 21, 2009 1:19 p.m. walterj Dork
I think you need the weight component - the calculated force of load smashing the tire into the road at full deceleration.
April 21, 2009 3:00 p.m. AngryCorvair Dork
yes. and like walterj said, it does depend to some extent on the vertical load on the tire.
since you're talking about FSAE, the tire supplier might give you some really valuable tire data, which they typically guard very closely. i can help you make sense of that data, and of course i would honor whatever non-disclosure agreement you have to sign with the tire supplier.
April 22, 2009 11:28 a.m. 96DXCivic Reader
Ok so I got told by a tire manufacturer a ball park figure of a longitudinal frictional coefficient of 1.8-2.0. Is this the same as peak grip?
April 22, 2009 11:41 a.m. AngryCorvair Dork
yes.
April 22, 2009 11:46 a.m. 96DXCivic Reader
Thanks for all the help
