dj06482
dj06482 GRM+ Memberand HalfDork
5/14/12 3:01 p.m.
This is actually for my Dad, who's allegedly having fun replacing the battery on their '94 Corvette. I know there is a pretty good C4 contingent on here, any tips?
Thanks!
Cotton
Cotton Dork
5/14/12 3:12 p.m.
I think I ended up pulling off a portion of the cruise control and was able to wiggle the battery out. It's been a few years, but that's all I did iirc.
novaderrik
novaderrik SuperDork
5/14/12 3:31 p.m.
most Vette owners would just drop it off at the shop and let them worry about it..
Cotton
Cotton Dork
5/14/12 3:55 p.m.
novaderrik wrote: most Vette owners would just drop it off at the shop and let them worry about it..
He said vette, not BMW.
Ranger50
Ranger50 SuperDork
5/14/12 3:57 p.m.
You expect the old geezers to work on cars at their advanced age?
nervousdog
nervousdog HalfDork
5/14/12 4:02 p.m.
The side piece with the gills next to the battery comes off. I just did it yesterday. 2 Torx bolts in the wheel well, one 10mm bolt up top, and loosen one 10mm on the bottom between the piece and the frame on mine.
Edit: Now with hotlinks!
conesare2seconds
conesare2seconds Reader
5/14/12 4:09 p.m.
Correct. The bottom one is hard to see until you crouch down, def requires a box wrench.
daytonaer
daytonaer Reader
5/14/12 6:57 p.m.
Just take the fender'ette off, its the easiest way. Don't struggle with the criuse and cross brace.
When you put it back on, mind the fender-door gap, there is enough "adjustment" that you can get the fender and the door to rub. Doing this did not improve the looks of my c4 when I had it.....
patgizz
patgizz GRM+ Memberand UltraDork
5/14/12 8:54 p.m.
yep pop the "fender" off.
i can do it in a minute now. actually mine hasn't been on for 2 years.
novaderrik
5/15/12 3:25 a.m.
this one seems to be trying to work on his car..
Bobzilla
Bobzilla SuperDork
5/15/12 7:34 a.m.
Not a geezer, but has been working on his C4 for a few months..... or I should say "Too damn long."
dj06482
5/15/12 7:40 a.m.
Dad's still young enough to work on cars! After all, I learned most of what I know from him.
He found a good how-to on the internet and so he went with the mini-rocker panel removal. Everything's buttoned up and still not starting. I've asked him for more details about any Check Engine lights or SECURITY lights. Replacing the battery was a smart move, though - it had last been done in 2003 (just before he bought the car).
What's the best C4 forum for tech? I was on Corvetteforum.com in the C4 technical section and it seemed pretty solid, is that the best one?
Thanks for all of your help!
patgizz
5/15/12 8:43 p.m.
corvette-guru.com
MFdbJr40rnjRxWR6qIJZBcgzrXABisFTuLy994R3TvqwYk115bHjXWMqwDlExWPm
