Login to post Forums » Grassroots Motorsports » Capri XR2 suspension same as???
  • dansxr2
    June 28, 2011 9:25 a.m. dansxr2 Reader
    Any similar mazda/ford interchange? Maybe looking into polyurethane bushings.
  • JThw8
    June 28, 2011 9:29 a.m. JThw8 SuperDork
    Dan, I assume you are a member over at TeamCapri.com? That will be your best resource. From what I could find when I was researching it there is no interchange and few if any parts available suspension/bushing wise for the XR2.
    One of the members there, long ago, appearently sat down with the Energy suspension catalog and took measurments to find "universal" bushings that would work. There is a rumored list, I keep finding references but not the actual list, of all his research with Energy Suspension part numbers and modifications needed to each if any.
    I never got far enough to need it but maybe if you ask around over there someone still has a copy of that information.
  • 92CelicaHalfTrac
    June 28, 2011 9:31 a.m. 92CelicaHalfTrac SuperDork
    Isn't that a slightly modified BG chassis? I bet it shares at least SOME bushings with the Protege/Escort/Tracer/323.
  • pinchvalve
    June 28, 2011 9:36 a.m. pinchvalve SuperDork
    In the first test I read about the XR2, it beat the Miata. (it wasn't in GRM)
  • RossD
    June 28, 2011 9:38 a.m. RossD SuperDork
    What about asking this guy for some info?
  • JThw8
    June 28, 2011 9:52 a.m. JThw8 SuperDork
    Rocketman is one of the primary experts over on TeamCapri
    However his car has a fully transplanted 323 AWD setup in it so it is even more 323 than the standard Capri.
  • RossD
    June 28, 2011 9:58 a.m. RossD SuperDork
    In reply to JThw8:
    Thats kind of my point. Maybe you can swap a sub frame or two and get back to 323 stuff and then have access to lots more aftermarket potential.
    What about buying poly rods or pouring your own poly bushings from stuff from McMaster Carr?
  • JThw8
    June 28, 2011 10:15 a.m. JThw8 SuperDork
    RossD wrote:
    In reply to JThw8:
    I understand but if you look at his project it's sadly not simple subframe swaps, there was alot of fabrication involved in making it work.
    Some of the guys over there have gone the DIY route, I dont think anyone has poured their own but a few have made their own out of poly rods in a lathe.
