Login to post Forums » Grassroots Motorsports » CEL on '06 Sedona
  • Klayfish
    Nov. 8, 2011 6:38 a.m. Klayfish HalfDork
    The CEL has been cycling on and off of my '06 Kia Sedona for a good month now. It's been running fine. I finally got the chance to take it to Autozone over the weekend to pull the codes down. Yeah, I know, what took me so long? I don't drive it much and just haven't gotten around to it. Anyhow, it had 3 different codes. I forgot to bring them here with me, but they basically all were saying the same thing. They're saying that at idle, the engine is running lean. There was one code for each cylinder bank, and I forget what the other was, but it was related to running lean.
    Of course, it lists a whole host of "potential causes", but they're very vague. Any thoughts on what would cause both cylinder banks to run lean at idle? The van seems to run and drive perfectly fine, so I don't notice anything obvious.
  • Streetwiseguy
    Nov. 8, 2011 7:02 a.m. Streetwiseguy Dork
    Both banks lean is going to be a split pcv or intake hose, or a slightly out of range maf, or a weak fuel pump, etc. Start by looking at air hoses.
  • iceracer
    Nov. 8, 2011 9:55 a.m. iceracer SuperDork
    If we had the codes, we might be able to get closer to the problem.
  • Klayfish
    Nov. 8, 2011 10:45 a.m. Klayfish HalfDork
    Yeah, I feel dumb for not having them with me. They're on a print out at home. I'll grab them tonight.
  • Klayfish
    Nov. 9, 2011 6:40 a.m. Klayfish HalfDork
    OK, so here are the codes that we pulled down.
    P2187 - System too lean at idle bank 1
    P2189 - System too lean at idle bank 2
    P0174 - Bank 2 system too lean
    Of course, it gives a whole host of "probable cause" items. Large vacuum leak, fuel system fault, ignition system malfunction, engine mechancial fault. But those are very broad reaching. Trying to figure out where to look first.
  • jstein77
    Nov. 9, 2011 7:23 a.m. jstein77 Dork
    Look for a vacuum hose hanging loose?
  • Ranger50
    Nov. 9, 2011 7:57 a.m. Ranger50 Dork
    If you don't have an increased idle speed, I would check the fuel pressure. I have seen where the pump drops pressure, PCM increases PW, and nothing changes, which just gets you a MIL.
  • iceracer
    Nov. 9, 2011 9:39 a.m. iceracer SuperDork
    Run some fuel system cleaner through it. Could be dirty/sticky injectors. temperature sensors can cause a lean condition. Since the problem is only at idle, I don't see fuel pressure being the problem. But it still should be checked. Dirty MAF or poor MAP readings are suspect. Do a thorough visual check to look for anything amiss. Always a good idea to check the grounds.
