Login to post Forums » Grassroots Motorsports » Challenge Saftey - Battery Box
  • kcbhiw
    Sept. 25, 2009 10:03 p.m. kcbhiw Reader
    I scored a used sealed lead acid battery from a decommissioned control panel a few months ago. I relocated the battery to the trunk of the Tracer and have been using it with no problems since. My question is, since this is a sealed battery, do I still need to enclose it in a proper battery enclosure?
    Info on the battery can be found here: http://parts.digikey.com/1/parts/1440-batt-sealed-lead-acid-12v-28ah-lc-x1228p.html
  • aussiesmg
    Sept. 25, 2009 10:21 p.m. aussiesmg SuperDork
    If it is a fully sealed battery it doesn't need to be enclosed, if it is behind a firewall it doesn't need to be enclosed, however extra safety is never a bad thing
  • mad_machine
    Sept. 25, 2009 10:46 p.m. mad_machine SuperDork
    enclosed might be good just to keep the cables from contacting anything if it comes loose
  • Sept. 26, 2009 10:14 a.m. blizazer New Reader
    You wont have to worry about random metallic objects in the trunk coming in contact with the battery either.
