So, we're on our way down to the challenge (in conneticut) and we are having some problems with our 1995 Suburban tow rig. It has the 5.7l V8. The motor started surging, cutting out, and surging more. When you give it throttle, it seems fine, but on decel, it will stumble. You can maintain constant throttle and it feels like it slows down and then it fells like it will advance timing all on its own and will feel fine for a minute, and then doing it all over again. It has a erratic yet cyclical pattern.
It just had a complete tune up, timing is set correctly, and it still does it. Then, we threw a coil at it (it was original and this thing has 217,000 miles) and it made it worse. So we started disconnecting more sensors one by one, and when we disconnected the map sensor, it smoothed out. We threw a map sensor at it and it STILL DOES IT!
Right now we hit the road again with the map sensor disconnected and its doing ok, but we want to really fix it. I think its only working because its in limp mode. Check engine light never came on until the sensor was disconnected. What do you guys think?
