Login to post Forums » Grassroots Motorsports » Civic Sleeper Sedan
  • PHeller
    Oct. 10, 2011 8:14 a.m. PHeller Dork
    There is a good chance I'll be getting a very nice condition 95 Civic 1.5L sedan for a good price. Tragically automatic. I'll likely leave it complete stock, but just for fun:
    What would be the best bang for buck in engine improvements? Something that'll still get 33mpg average, but actually be fun.
    It'd also have to be a really straight-forward swap. I'm mechanically inclined, but working out of a small backyard garage.
  • unevolved
    Oct. 10, 2011 8:23 a.m. unevolved Dork
    A single-cam D16Z6 VTEC swap can be done for really cheap, and boosted for even cheaper. Junkyard turbo, second-hand cast manifold, and eBay intercooler and piping kit. Swap in some DSM injectors and run an emulator with Crome Pro and you're looking at 250whp for about $1000 or so invested. Off boost you'll still hit 30mpg no problem. It's a real easy swap if you get the right parts, and there's no fabrication involved.
    NA power? Not happening on a "bang for buck" scale.
  • PHeller
    Oct. 10, 2011 8:32 a.m. PHeller Dork
    Wasn't sure if there was a cheap/easy larger displacement swap out there now'a days.
  • Gearheadotaku
    Oct. 10, 2011 8:37 a.m. Gearheadotaku Dork
    I think the best results will come from swapping in a manual trans. Makes the best of the engine you have and will improve mileage even further.
  • PHeller
    Oct. 10, 2011 9:07 a.m. PHeller Dork
    Yea probably. The car will actually be my girlfriends, and she can't drive manual comfortably.
    That's not to say some day down the road the Civic won't be mine.
  • 93EXCivic
    Oct. 10, 2011 9:30 a.m. 93EXCivic SuperDork
    I have seen some F-series out of Accords swapped in and they are cheap but they will require fab work and a different transmission.
  • N Sperlo
    Oct. 10, 2011 9:45 a.m. N Sperlo Dork
    Images of a 351 in a civic ran through my head.
  • PHeller
    Oct. 10, 2011 9:53 a.m. PHeller Dork
    I did a quick search and it appears the F22 just isn't worth it in terms of fab-vs-performance.
    There is a B20, but those are relatively expensive I guess.
  • AngryCorvair
    Oct. 10, 2011 10:07 a.m. AngryCorvair SuperDork
    nitrous oxide
  • integraguy
    Oct. 10, 2011 12:01 p.m. integraguy SuperDork
    Having owned one, a B18A engine and it's transmission (manual, tho) would meet most of your needs and is a definite sleeper. With the automatic that must also come from the same car as the engine...you won't get 33 mpg. You will get close...maybe 30 or more, but on the hiway at cruising sppeds of about 70 mph. In town driving? About 28 mpg.
  • 93EXCivic
    Oct. 10, 2011 12:08 p.m. 93EXCivic SuperDork
    The F22 is soooo cheap though.
  • unevolved
    Oct. 10, 2011 2:35 p.m. unevolved Dork
    AngryCorvair wrote:
    nitrous oxide
    Nitrous on a E36 M3ty Civic engine:
  • wbjones
    Oct. 10, 2011 4:11 p.m. wbjones SuperDork
    B16 with cams ... ( type R cams on a friends = 175 to the wheels )
  • Taiden
    Oct. 10, 2011 4:38 p.m. Taiden Dork
    Do a B20 bottom end with any VTEC head and a decent tune if you want budget NA power.
    The b20 came from the Honda CRV. This may be a junkyard swap.
    Use a GSR transmission as they are a good 'compromise' between the loooong MPG savvy LS transmission and the shoooort B16 transmission. (I won't even get into the ITR tranny)
  • 92CelicaHalfTrac
    Oct. 10, 2011 4:44 p.m. 92CelicaHalfTrac SuperDork
    Take one parts:
    B18B (Integra ls) block
    B16 head
    CTR pistons (cheap from your local honda dealer, 12.5:1)
    ITR cams
    CTR valvesprings and retainers
    Attach to transmission of your choice. Enjoy LOTS of power.
  • PHeller
    Oct. 11, 2011 7:32 a.m. PHeller Dork
    Sounds like we're making a Spoon Civic Sedan...
  • 92CelicaHalfTrac
    Oct. 11, 2011 7:34 a.m. 92CelicaHalfTrac SuperDork
    Needs more SR20. Just get them far before Race Wars.
  • turboHLS30
    Oct. 11, 2011 7:49 a.m. turboHLS30 Reader
    My dad has a '93 Civic hatch that we put a junkyard B18b into and threw a 150 shot of nitrous on it. Ran 11.8 consistently all day. You can find B20's for $500-$1,000, or you can find B18A1's everywhere and those are good motors. My dad's friend has a LS/V turbo in his '89 Civic hatch that runs 11.8's and he daily drives it. He's driven the car daily for about 2 years now, and one of the cylinders are just starting to get low on compression. There's PLENTY of bang for the buck options, it's just up to your preferences.
  • 93EXCivic
    Oct. 11, 2011 7:53 a.m. 93EXCivic SuperDork
    If you want more power, turbo'd D-series is the answer IMHO.
  • gamby
    Oct. 11, 2011 8:42 a.m. gamby SuperDork
    Way cheaper than finding a decent B-Series VTEC these days.
  • PHeller
    Oct. 11, 2011 3:03 p.m. PHeller Dork
    Just discovered that MPG will not be as high as I was hoping in the city with the automatic.
    Still better than the girlfriends 18mpg Thunderbird in town.
  • Matt B
    Oct. 11, 2011 3:13 p.m. Matt B Dork
    I'm going to vote B18b as well. The compression is low enough to handle mild boost and it's pretty drop-in compared to the F-series. Plenty of transmissions to choose from as well.
  • neon4891
    Oct. 11, 2011 4:42 p.m. neon4891 SuperDork
    All I have to say on the auto Vs. stick, My wife had a 97 civic slusher. It was a nice drive, but a 5spd would have made it perfect.
