Login to post Forums » Grassroots Motorsports » Cleaning Glass AKA When should I change my winshield?
  • digdug18
    Aug. 27, 2010 7:10 p.m. digdug18 HalfDork
    Over the couple of years I've tried just about every streak free or invisible window cleaner on the market, with limited success. There are fines lines on the windshield, along with a haze from grease/road grime and whatever else that never seems to leave after a cleaning.
    So where does it stop, I could live with the fine lines, I figure since my car is a '94 I should expect the acid rain, wiper movement and small stones to make any windshield with my car's age a little beat up.
    The grease and haze i cannot live with and have tried every product to get rid of it, some leave more of a haze or a sheen that turns sun glare unbearable.
    So my question is where do I draw the line? Should I get a newer windshield, or is there a product out there that dries to a sheenless/haze free finish?
    Andrew
  • stuart in mn
    Aug. 27, 2010 7:40 p.m. stuart in mn SuperDork
    The old school way of cleaning glass was to use Bon Ami cleaning powder: http://www.bonami.com/index.php/products/powder_cleanser/ It won't do anything about the little freckles you get from rock and sand; you may be able to polish some of that out with a glass polishing kit from Eastwood company: http://search.eastwood.com/search?asug=glass&w=glass+polishing+kit&p=Q&... If the damage to the windshield is severe enough, it may be worth replacing it. Check your insurance policy; in some states glass replacement is a zero deductible on your comprehensive coverage.
  • Woody
    Aug. 27, 2010 7:48 p.m. Woody SuperDork
    Kick out the glass and get a pair of these:
  • digdug18
    Aug. 27, 2010 8:18 p.m. digdug18 HalfDork
    I considered the polishing of the glass, but I would imagine that could be a short term solution as well. I'll look into it further though.
  • Toyman01
    Aug. 27, 2010 9:56 p.m. Toyman01 Dork
    Most truckers I know change their windshields every 100K due to sandblasting. The ones in my work vans usually go about 70K before I replace them, usually due to cracks, but the sandblasting gets pretty bad by then. Replace it and you will be amazed.
  • Jensenman
    Aug. 27, 2010 10:09 p.m. Jensenman SuperDork
    Polishing those little sand pits is a PITA. I have a bud who started a glass polishing bidness, it wound up being cheaper for people to replace windshields than to pay him to polish them out because it took damn near all day. He moved to polishing headlights, then that got screwed by all those DIY headlight kits (which suck, BTW).
    I'd look into another windshield. Come to think of it the Trooper's about due for one, driving into the sun is a bitch.
  • M2Pilot
    Aug. 27, 2010 10:10 p.m. M2Pilot Reader
    I tried the Eastwood product several years ago,you're right about it's not doing anything for the freckles, it helped some for scratches.
  • Rad_Capz
    Aug. 27, 2010 10:11 p.m. Rad_Capz Reader
    I've used the Eastwood kit and spent hours and hours. Never again! I just buy new windshields. Seems like a lot till you look out through the clear glass while driving at night.
  • Lesley
    Aug. 27, 2010 10:13 p.m. Lesley SuperDork
    I don't mind driving old beaters, as long as the windshield's new. There's a guy here who'll come to your place and install it for $200 cash. I just can't frigging see at night through scratches and stars and E36 M3.
  • doc_speeder
    Aug. 28, 2010 9:35 a.m. doc_speeder Reader
    I just got a new windshield 2 days ago in my beater Mk2 Jetta. The old one was scratched, cracked, and sandblasted. It feels like I'm driving a whole new car! Pretty cheap too for most older cars.
  • Aug. 28, 2010 9:46 a.m. thestig99 New Reader
    I draw the line when inspection becomes an issue. Like this in my old '95 Saab 900S (thank you, air bag!):
    Photobucket
  • Junkyard_Dog
    Aug. 28, 2010 10:23 a.m. Junkyard_Dog HalfDork
    Windshields are too cheap to not replace.
    Bonus-if you have glass coverage and a chip/crack it might be free!
  • digdug18
    Aug. 28, 2010 2:05 p.m. digdug18 HalfDork
    Now if I could get a windshield in a dual pane version, so I'd never have to deal with a foggy windshield again.
  • novaderrik
    Aug. 28, 2010 4:19 p.m. novaderrik Reader
    carb cleaner on a rag is pretty good at removing haze from a windshield. follow up with some Windex (the actual stuff, not the generic blue glass cleaner) and it will be as clean as it's going to get.
  • Aug. 29, 2010 7:38 p.m. spitfirebill Dork
    I seem to recall that polishing a DOT windshield enough to remove pitting may not be kosher.
    I've been dealing with a sand pitted windshield in my Nissan truck for years, hoping someone would break it. No such luck. I have a neighbor that couldn't keep a windshield in his Ford van.
    Oh and Coke (the cola) does wonders for cleaning a windshield.
  • digdug18
    Aug. 30, 2010 10:35 a.m. digdug18 HalfDork
    I'll try both the coke and brake cleaner.
  • digdug18
    Aug. 30, 2010 10:40 a.m. digdug18 HalfDork
    not at the same time, though that might make it really really clean
  • Karl La Follette
    Aug. 30, 2010 2:14 p.m. Karl La Follette HalfDork
    A piece of high quality laminated dupont polymer film also known as tearoff product
  • ArthurDent
    Aug. 30, 2010 2:55 p.m. ArthurDent Reader
    I did the Coke thing an old Dodge Shadow windshield - made it notably worst - a bit foggy all over. Maybe I did it wrong ...
  • Twin_Cam
    Aug. 30, 2010 5:55 p.m. Twin_Cam Dork
    I suggest Brakleen with a clean rag to get the grease off, and then:
    SOLUTION TO YOUR PROBLEM: 0000 (very fine) steel wool!!!!
    Get it from a hardware or painting store. It is the only thing in the known universe that can remove that last bit of windshield haze without causing it to streak even worse. Trust me. I've tried EVERYTHING. It's a bit of a pet peeve of mine. Don't argue, just go find some.
    Use light, circular polishing motions to remove the haze. One thing to note is that if you polish one area for too long, you can start to scrape the glass, but it's hard to do with really fine steel wool. If you use medium or coarse steel wool, you'll definitely ruin the glass.
  • digdug18
    Aug. 31, 2010 3:02 p.m. digdug18 HalfDork
    I will try it, as its cheaper then replacing the windshield. Though its only $186 installed, but I'd rather spend that money elsewhere.
  • Twin_Cam
    Aug. 31, 2010 5:48 p.m. Twin_Cam Dork
    I'm telling you, the steel wool thing works. Haze really bugs me, especially when it is humid, but not hot enough to warrant turning on the A/C to clear it up. Once you clean it completely, it won't even fog over in humid weather.
