So... in the engineering/designing stages of my 66 Bonneville project I came up with a possibly lame idea... or a brilliant one.
The car will have an air suspension and (since the engine will be a duramax) I have the option of a belt-driven pump. Having driven a few air-suspended cars I have always been disappointed in their performance. You let it sit for a week and then you have to wait for it to build air pressure. It kinda takes a daily driver and turns it into a bit of a burden to drive unless you go way overkill with huge tanks and lots of electrical draw for large pumps.
So, I have this CO2 tank sitting here. Its rated for 1800 psi and probably has a capacity of about 4 gallons. Theoretically if I charged it to 300 psi, it would have the same capacity as an 8 gallon tank at 150 psi. What if I were to charge it to something like 500 psi? Can I find a pump that will do it? Will such a pump break the serp belt or cause it to slip like crazy?
I'm just thinking of ways of making the system more compact/efficient. I feel like adequate air generation and component size is the big limiting factor in air suspension performance.
