californiamilleghia
californiamilleghia HalfDork
5/9/19 1:51 p.m.
Hi , we just had some suspension parts cut out by waterjet , and we still need to weld them together
But then we need to paint them , they cannot be powercoated because there are too many hidden areas that powder coating will not get into.
So we were thinking of dip painting them in a bucket of Rustoleum.
It is only to keep the raw bare metal from rusting ,
What would you use to thin the Rustoleum with ,  and what will dry out the paint the best ?
Has anyone done this before ? Any tricks or disasters to look forward to ?
Thanks for your advise
Dusterbd13-michael
Dusterbd13-michael MegaDork
5/9/19 1:54 p.m.
When spraying Rust-Oleum on an automotive exterior application, we sent it with mineral spirits and add a touch of hardener. I don't see why this wouldn't work for dip painting as well.
Dr. Hess
Dr. Hess MegaDork
5/9/19 2:14 p.m.
"Mineral Spirits" based regular, not slow, paint thinner.  Cheap at Wally world or Lowes.  You can also use acetone, but I always thin with mineral spirits paint thinner.  I've added hardener occasionally also.
Dr. Hess
Dr. Hess MegaDork
5/9/19 2:16 p.m.
Oh, also, when you're done and it has air dried, try to hang is up in your shop oven and bake it at like 200 or so until it stops smelling.  I think I have even gone to 300.  It really "sets" the paint.
stuart in mn
stuart in mn MegaDork
5/9/19 5:40 p.m.
I've read that back in the day auto manufacturers would dip paint some components (like suspension A-arms) by floating a thin layer of paint on top of a vessel filled with water.  I know some people have tried it at home with a water bucket.
californiamilleghia
5/10/19 8:15 a.m.
Hi,
What percent mineral spirits can I add ,?
I was planning on dumping the gallon of Rustoleum in a 5 gallon pail and adding mineral spirits.
Dr. Hess
Dr. Hess MegaDork
5/10/19 9:05 a.m.
I typically thin my Rustoleum 25-33% when spraying.  I don't see why you couldn't go 50%.  Or 0% and just slosh it around.  If you can get it, the Appliance Epoxy is incredible stuff.
SxkYT5qm5YSyQMNoDlErP6L80aEmPeMON2wgcRoFzVQSmSrWjehjZhaCyze3bjbc
