Ok, I am done banging my head against the wall with my old standalone, and I am thinking about MS3 or MS3 Pro. Engine is a built normally-aspirated, ITB'd Toyota 4A-GE currently running an FJO 341B with a cam angle sensor in place if the distributor, FJO waste spark ignition with two GM-based coils, sequential injection, and FJO wideband.
I want to reuse as much hardware as I can. I have a 60-2 trigger wheel, VR crank and cam position sensors, GM MAP sensor, Toyota TPS, GM coolant temp, air intake temp, oil temp, oil pressure, fuel pressure sensors, Jeep AIC valve, and RC engineering low-impedance Bosch-style injectors.
My wideband oxygen sensor is FJO, and I will have to ditch my FJO fuel injector driver and FJO ignition module as they are both mystery proprietary black boxes. It remains to be seen if I reuse my GM ignition coils with a new ign module, or get something altogether new.
Cooling fan and fuel pump could be run by the ECU or by separate switches/relays/sensors still in the car.
I am not going to solder together my own.
I don't really need all the features of the Pro, but my current ECU uses AMPseal connectors and an external GM MAP, so it might just take some repinning if my existing harness, which is a huge benefit!
Then again, the MS3 assembled should do everything I need and is quite a bit more affordable.
Thoughts? Words of wisdom or voices of experience?
