turboswede wrote:
Might try to back the adjusters off as the shoes can have a habit of wearing grooves into the drums and the shoes get hung up in the grooves sometimes.
Typically, removing the outer wheel bearing allows the drum to essentially fall out.
Hope this helps!
Thanks, I could take the bearing apart but that undoubtedly entails its own set of issues that I would rather avoid. The DIY on Allpar suggests that route.
I have never gotten the hang of just how Chrysler's self-adjusters work. In their INFINITE wisdom they route the e-brake cable directly across the access port so you can't see a damn thing. Do you need 2 screwdrivers in there (1 to lift the pawl, and 1 to spin the wheel)? And which way do you spin the wheel?
Vigo, there's no play, it's solid. I already pickled around the hub with PB. I just didn't want to go wailing pointlessly on cast iron if it was actually bolted on somehow.
I may go take a run to get a bar puller before I try to take the wheel bearing apart. I understand the bolt holes are M8X1.25 thread?
Thanks, gents.
