Login to post Forums » Grassroots Motorsports » Dumb question--Miata/E30 wheels
  • mtn
    Jan. 15, 2010 1:02 p.m. mtn SuperDork
    I think I might have asked this before, but can't find the thread and can't remember the answer. Do miata wheels fit on an E30? I know they have the same bolt pattern, but haven't seen any on the web with miata wheels.
  • EvanB
    Jan. 15, 2010 1:04 p.m. EvanB HalfDork
    The Miata wheels have a very small centerbore (54.?mm) and the E30 centerbore is likely larger (I don't know for certain) so you will probably have to bore the center out a bit for it to fit.
    EDIT: Just read the E30 wheels have a 57.1mm centerbore so it wouldn't take much to bore it out a bit.
    Here is a thread that I started a long time ago about it: http://archive.grassrootsmotorsports.com/board/viewtopic.php?id=29750
  • ZOO
    Jan. 15, 2010 1:30 p.m. ZOO Dork
    Does the E30 use a stud and lug nut combo, or a lug bolt? That may be something to consider.
  • mel_horn
    Jan. 15, 2010 2:04 p.m. mel_horn Dork
    It's bolts. Or it are bolts. Or they are bolts. Oh, berkeley, you get the idea...
  • mad_machine
    Jan. 15, 2010 2:50 p.m. mad_machine PowerDork
    lug bolts on the E30 and most BMWs (not sure on the newest models)
