Login to post Forums » Grassroots Motorsports » Ej20tt & 6 speed into a '99 Impreza Sport wagon
  • Oct. 30, 2011 5:11 p.m. mdshaw New Reader
    Would this be an easy swap since all things would be Subaru? Would the axles match the trans? What drive shaft would be required, since the trans would most likely be longer - custom? I will go Mega squirt for the ecu so that's covered.
  • sachilles
    Oct. 30, 2011 5:21 p.m. sachilles Dork
    6 speed is fine, might need a new rear diff. I think you just get a drive shaft from an automatic car. The twin turbo doesn't fit in left hand drive vehicles I believe, but confirm that.
  • Taiden
    Oct. 30, 2011 5:31 p.m. Taiden Dork
    Actually yeah, it should be fairly straight forward.
    For the 6 speed you will need a lot of things from the STi.
    It is often easier to just start with one as a donor.
  • Oct. 31, 2011 8:31 a.m. NGTD Dork
    ^^^^^^ This.
    Apparently the second turbo is exactly where the steering shaft goes. Two turbos or steering - pick one.
  • Osterkraut
    Oct. 31, 2011 8:45 a.m. Osterkraut SuperDork
    Turbos. Duh. You can steer with boost, but can't make boost with steering.
  • Oct. 31, 2011 9:19 a.m. mndsm SuperDork
    learn to steer with the pedals and the e-brake?
  • Oct. 31, 2011 9:54 a.m. mdshaw New Reader
    Good points - no more tt. Will also need to do some ratio research. I think I'll do the motor first then the trans later. It has a new 5 speed any way. Even the 2.2 is still going strong though - 208k but need some more oomph. There are rumors that certain RS n/a ecu's work fine with some turbo motors. Subscribed to rs25.com - let the research phase of the project begin.
  • BoxheadTim
    Oct. 31, 2011 10:13 a.m. BoxheadTim SuperDork
    I've owned a twin turbo Legacy - the engine characteristics take a little getting used to as there is a 'valley' between the first turbo running out of breath and the second one kicking in. You get used to it (and there are things you can do to fix this issue) but for that reason alone I'm not sure I'd want to use it as a swap candidate.
