I rebuilt the front suspension on Dr.Linda's S2 Europa.
Here's some pics (a before and an after):
and:
I stripped everything down, bead blasted and then painted anything not replaced. New rotors, bushings, bearings, seals, ball joints, rebuilt calipers (Amazon.com) then painted red, and a nut welded to the end of the bearing cover so the thing will actually come off with a slide hammer, "minor" trunnion kits plus seal. Harley Davidson wheel bearing grease (the best out there) and Mobil SHC630 gear lube (yes, even an English car's SUSPENSION is capable of leaking oil.) Quite a bit of work. Parts sources were: Amazon.com, Spitbits, Ray (RDent.com). Specialty tools: HF 20 ton press, HF bead blaster, HF MIG.
