Login to post Forums » Grassroots Motorsports » F2T Help Needed Please
  • dansxr2
    Jan. 8, 2012 12:08 a.m. dansxr2 HalfDork
    so the transmission went out a couple weeks ago so today i pulled the engine and transmission to replace the trans.... I discovered oil coming from my Compressor Housing :-/ anyways should I get a new GT2871R (which it has now with IHI Exhaust housing and some sorta different compressor wheel/housing combo, or get a new VJ-11? Both are about the same price. Car is used as a fun/autoX/driver nice weather only (no snow)....
    Second issue is I think I'm gonna put a new clutch in the Probe too.... The clutch moves, but not far enough to release fully... This is my problem with these cars, i guess the torque is rough on the drivetrains...lol o well, fix it and make it better, right?
    Input, Ideas, words of wisdom???
  • 92CelicaHalfTrac
    Jan. 8, 2012 8:12 a.m. 92CelicaHalfTrac SuperDork
    Under no circumstances would i ever put a stock turbo on one of these if i had the option of something else.
    Just rebuild the turbo. Should be $150 or less, look for a diesel shop.
    Words of wisdom: Re-use the mazda axle retaining clips.
  • dansxr2
    Jan. 8, 2012 8:36 p.m. dansxr2 HalfDork
    its a ball bearing turbo so i have to replace the center cartridge...its $617 for a new one :-/ know of any other turbo that i will bolt up pretty easily? maybe VF-34 or VF-22???
  • 92CelicaHalfTrac
    Jan. 8, 2012 10:14 p.m. 92CelicaHalfTrac SuperDork
    Ehhh, i'm not big on the hybrids, don't know which ones are which.
    Nothing else will 100% bolt on, unless you find a TKT/JGS Tools hybrid.
    There's a bolt-on hybrid made with a Volvo 16T wheel for sale on MX6.com right now.
    I think a VF12 was also an upgrade? Don't remember what needed to be done to run that, though.
    Honestly, i think it sounds like it's time to get ahold of a T3-flanged manifold.
  • Jan. 8, 2012 10:30 p.m. mndsm SuperDork
    I agree. Plus then- you can strap ALL the turbo to it, which is the right thing to do with an f2t.
