Another fun day at the autocross today, but I was having issues with the fronts locking up WAY before the rears. This is common and understandable on a first-gen MR2 with so little weight over the front. With stiffer sway bars and upgraded coils, I get less weight transfer to the front which makes the situation even worse. I am researching ways to reduce this and stay STS legal.
One option is the relocate the battery to the frunk to put some weight up front. This has the added benefit of re-distributing weight and lowering the CG slightly. I don't know how much this would help, but it has other benefits and cant hurt as far as I can see.
The next thing to do is to upgrade the brake lines to braided SS lines. If it does nothing else, it replaces lines that are pushing 25 years old! I also like the feel of ss lines and the added security. Will it help braking performance? Not much, but it will help the overall system so its a no-brainer.
The next thing on my list is replacing the Hawk HP+ front pads with basic OEM pads. This should give less bit in the front for better balance, and I found the tip by searching GRM.com so it must work!
Finally, I have read about removing the guts from the stock proportioning valve to remove the front-lock bias. 1) does this actually work? 2) is this 100% legal for STS? There is no mention of changing the stock components or adding a proportioning valve, but usually if it doesnt say you CAN it means you CANT. The car sees little road use and I can certainly handle the change in braking dynamics. I'm not a bend the rules kinda guy.
Any other thoughts?
